Throttle body performance.
Old Aug 19, 2012 | 11:23 AM
Glenn88Iroc88's Avatar
Car: 1988 iroc-Z 5.7l TPI
Engine: 5.7l TPI
My car has the HSR intake set-up with a BBK TB.
Is a throttle body spacer a decent upgrade worth doing?
Should i buy a holley 58MM TB to replace my 52 MM BBK?
Theres also a flow booster out there... are those worth buying/ installing?
Old Aug 21, 2012 | 11:28 PM
Vader's Avatar
Re: Throttle body performance.
If you are using a stock cam and/or stock heads the extra flow of a 58mm TB will not be advantageous - Your engine cannot use it. Consider the fact that the 502 RamJet used the same stock 48mm TB on the 500+ CID engine to make an honest 500+HP, and you may realize that intake flow is probably not the most significant factor limiting power production. You already have a 52MM TB and probably aren't pushing out 500HP (yet).
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
