High Engine Idle - 305 TBI
Old Aug 23, 2012 | 09:06 AM
joshhsi's Avatar
Car: 1991 Camaro Z28
Engine: 305 TBI
Transmission: 700r4 w/B&M Shift Kit
I dropped a 305 TBI from a 92 RS into my 91 Z28 a few years back and ever since, it has had a high idle. When first starting the engine, it idles around 2,500 RPM. Once the engine warms up it will kick down to around 1,000-1,500 RPM. This still seams a bit high to me. I replaced the IAC Valve and checked all the vacuum lines for leaks. Any suggestions?
Old Aug 23, 2012 | 10:48 AM
grygost's Avatar
Car: 1991 GTA Purple of all colors
Axle/Gears: Crappy 3.23
Re: High Engine Idle - 305 TBI
Throttle position. Check and see if you have the ability to adjust it.
Old Aug 23, 2012 | 11:19 AM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
I've got the same exact problem.
Old Aug 23, 2012 | 11:27 AM
grygost's Avatar
Ok, TBI is no idle adjustment but what controls it would also be the IAC. Check the IAC out and make sure it is working, also vacuum leaks cause a high idle as well. Disconnect the battery for a bit then reconnect and see where the idle is. if its still high also check the TBI gasket where the manifold is. Spray starter fluid around the base and see if the idle rises. If it does theres a leak.
Standing in front of the your engine, it's on the left front side of the TBI, will have some wires plugged into the end, has a hex on the end about 1" or so diameter, but it would be metric. A large Crescent wrench will fit.
After you pull the IAC, use a light to check inside the port for carbon chunks. (shop vac is great to pull loose carbon out)
Your idle should be near 1500 rpm with the IAC removed, just a real fast idle.
Then cover the inner port with a finger, the idle should drop to normal if the IAC or it's circuitry is the problem.
Old Aug 23, 2012 | 11:48 AM
nickfrmtx89's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L TBI
i have the same problem on my 92 RS w/ a 305 TBI. turns out my tachometer is off about 500-1000 RPM's over and if you read some of the threads on here thats a common problem for these old 3rd gens.
Old Aug 23, 2012 | 04:05 PM
joshhsi's Avatar
Engine: 305 TBI
I found some info online about jumping the A and B pin to reset the IAC, then unplug the electrical connector and use the idle screw on the side of the throttle body to lower the idle. I turned the darn screw until it just about came out of its hole and got the rpm's to come down to about 1000 with a hot engine. I have a newer IAC in, but I guess I can check for carbon buildup inside and try to check the TPS again. If those are all ok....I guess I have a vacuum leak somewhere then.
Old Aug 23, 2012 | 04:07 PM
joshhsi's Avatar
Engine: 305 TBI
It's not the tach. I did have the problem with the tach reading double a while back, but replaced the little circuit board and that fixed it.
Old Aug 24, 2012 | 08:25 PM
Car: 1992 Camaro RS
where did you find the circuit board?
Old Aug 25, 2012 | 07:32 AM
joshhsi's Avatar
Engine: 305 TBI
I found a complete guage assembly for sale on craigslist. There is a small board for the speedo and one for the tach as well.
Old Aug 25, 2012 | 03:02 PM
Car: 1992 Camaro RS
I removed the IAC and my car tryed to go full throtle.
Old Sep 3, 2012 | 09:26 PM
xstang77's Avatar
i had the same problem on my 305 changed iac as well discovered it was the ECT sensor causing the car to not go into closed loop my idle was around 1500 too checked the ect and i could swivel the connector changed the ect and it idles perfect now
Old Oct 23, 2012 | 06:00 PM
1989blueirocz's Avatar
Car: 1989 camaro iroc-z
I have the same problem, when my camaro gets to about 1/4th tank it idles at about 2,000 rpms but if I fill it up the idle is about 600-750. what would make it do that? Someone told me that wwhen the tank gets low there could be a spot where it's sucking air?
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
db057
Aug 22, 2015 08:17 PM
92purpz28
Aug 11, 2015 02:30 PM
