V6 v belt setup on a v8?
Old Aug 25, 2012 | 11:29 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
I went to the junkyard today search of a v8 setup and I came acrossed an 87 gta with v belts and they look just the same as my v6 system on my car now, had anyone actually looked and seen if this would work? I realize I'd need a v8 water pump but everything else looks like it will work.
Old Aug 25, 2012 | 07:25 PM
Engine: L31 350
Re: V6 v belt setup on a v8?
Bumb
Old Aug 26, 2012 | 01:23 PM
Vader's Avatar
Originally Posted by evilemokid94
...I came acrossed an 87 gta with v belts and they look just the same as my v6 system on my car now, had anyone actually looked and seen if this would work?
V-belts were standard through the 1987 model year on V-8s, including TPI. I'm not certain I understand the question. Are you asking if the V-belt setup would work for an engine swap? Or are you asking if the V-8 belt setup would work on the 60° V-6?
Old Aug 26, 2012 | 01:31 PM
Engine: L31 350
Would the v6 setup work on a v8 motor
Old Aug 27, 2012 | 12:31 PM
ex-x-fire's Avatar
The only v6 engines that are good donor for belt set ups are the chevy 90* v6s, like the old 229 & 4.3ls. The 60* v6 have different bracket mounting locations, crank bolt pattern is 4 holes, & most likely a more compact set up.
Galaxie500XL
Feb 1, 2020 04:53 AM
codeysabatini
Nov 10, 2015 04:07 PM
BDR
Nov 7, 2015 03:05 PM
scottmoyer
Sep 20, 2015 11:54 AM
MORREALE5
Sep 10, 2015 08:58 AM
