Vacuum connector
Old Sep 2, 2012 | 06:00 PM
oneoldman's Avatar
Car: 87 camaro/ 67 chevelle
Engine: 2.8l / 283 V8
Transmission: 700r4 / saginaw 4 speed
Axle/Gears: 3.42 / 3.08
Vacuum connector
I have a 87 Camaro 2.8L MPFI it has a double vacuum port on rear of upper plenum I know the large port is for the brake booster, I have a vacuum hose from the cannister in the left front fender and a very small short plastic line at the heater/a/c box coming out of the firewall I think both are for the heater controls but I need to know what type of connector marries them to each other and the port. The car was disassembled when I got it and pieces were missing.
Old Sep 2, 2012 | 06:28 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: Vacuum connector
Here's a diagram;http://www.chevythunder.com/fuel%20i...um%20lines.htm Then you'll probably have to go to a parts store and buy a selection of fittings and line and make your own such as these. http://www.autozone.com/autozone/acc...ubing/_/N-25ry
Old Sep 2, 2012 | 09:45 PM
oneoldman's Avatar
Thanks I've seen those diadgrams but the cannister I mentioned is the vacuum tank in the fender not the fuel vapor cannister all the other vacuum hoses are intact none of the hoses in the diagrams show the vacuum port that is screwed into the rear of the upper plenum or show them going to the tank or the firewall. Any other ideas are welcome
Old Sep 2, 2012 | 10:19 PM
red rock's Avatar
Car: 1987 iroc
From the fender vacuum tank, the line tee's to the cruise control servo then all the way back to a tee for the plenum and brake booster. That's what the factory manual show's anyway.
Old Sep 2, 2012 | 10:32 PM
red rock's Avatar
Car: 1987 iroc
I tried to copy my manual for ya.
Old Sep 3, 2012 | 03:38 PM
oneoldman's Avatar
That helps a little but I don't have cruise control. I may just try to tee the plenum port to each of the loose lines and see what happens. Like I said I think they are for the heater controls. The only diagram I found shows lines the back of the control not in the engine compartment.
Old Sep 3, 2012 | 03:45 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
You guys are so good with these computers that this old man will never catch up.
Old Sep 3, 2012 | 04:02 PM
red rock's Avatar
Car: 1987 iroc
Old man, I'm probably older than you! Maybe
gta892000
Aug 11, 2019 11:16 AM
ccop
Convertibles
Sep 14, 2015 04:13 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
middian
Sep 5, 2015 01:42 AM
