Speedo cable oil leak
Old Sep 6, 2012 | 06:17 PM
KITTClone's Avatar
I broke the speedo cable on the '83 Trans Am. I have tried replacing it by buying the cable & housing from Autozone and from NAPA. They both fit/worked OK, even though they are 2" longer. But they leak tranny oil at the tranny fitting. This is setting in the garage, not driving.
Has anyone else had this happen? After the A-zone leaked I got a NAPA part, thinking higher $, higher quality. No luck. The tranny fitting looks smooth, clean, no burrs. The tranny looks clean, no other leaks.
Any suggestions are welcomed.
Thanks.
Old Sep 6, 2012 | 06:43 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedo cable oil leak
Originally Posted by KITTClone
I broke the speedo cable on the '83 Trans Am. I have tried replacing it by buying the cable & housing from Autozone and from NAPA. They both fit/worked OK, even though they are 2" longer. But they leak tranny oil at the tranny fitting. This is setting in the garage.
My guess is that the leak is at the driven gear housing seals.
JamesC
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
drathaar907
Aug 6, 2015 04:20 PM
