Oil dipstick tube bracket spins with bolt
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
As with any simple job I attemp to do, it always turns into a multi day project. I'm one bolt away from swapping in a new pass side exhaust manifold gasket. The problem is that the whole stud is loose but the front nut is siezed to the oil dipstick bracket. Any attempts to loosen the nut, and the dipstick bracket twists and the dipstick moves. And I have been using pb blaster all day on it. I even tried holding the back bolt while trying to loosen. Will not budge.
Any tips on getting this off? I would rather not break the dipstick tube.
1985 305 TPI
1985 305 TPI
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Re: Oil dipstick tube bracket spins with bolt
Instead of holding the bolt, have you tried holding the bracket?
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Like grabbing it with a pair of vice grips and hold it with that? I could try. Thanks for the tip.
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Maybe warm it up a little but don't burn your car up.
The "bolt" isn't a "bolt" at all; it's a nut, on a stud.
Hold the hex on the stud still with an open-end wrench. Probably have to be a thin one. Might need to get one and grind it down.
Engine: 4++,350 & 305 CIs
Heat up your nuts then do your un-screwing!
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Holding the back stud while trying to remove the front nut is not working. Guess I am not strong enough.
What gaskets are you using??
This is what I use on headers, but a bit bigger size. I've never used a gasket with manifolds..
Can you get an impact in there? If so, hold the hex on the stud with a wrench (or vice grips) and give it a couple quick zaps with the impact. Impacts do a MUCH better job busting loose frozen fasteners than the steady pull of a hand-wrench does.
As was said above, heat is also your friend. Use the two together and you could loosen the main hull bolts on the Titanic, eventually.
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
I don't think there is adequate room for an impact for that bolt.. I would get some MAP Gas and heat it until it is cherry red but not white hot. That will assist it in breaking loose
ambainb
Apr 25, 2016 09:21 PM
Genopsyde
Nov 11, 2015 10:46 PM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
