20w-50 Valvoline Racing Oil okay for street?
Old Sep 12, 2012 | 06:30 AM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
After I break my engine in, I'm not sure what oil to put in it. I did a bunch of searching on this site, it sounds like the Valvoline 20W-50 synthetic is pretty highly recommended.
My car is more of a "weekend warrior", not a daily driver and won't be driven at all in the winter. It has a 383 stroker in it with a roller cam.
I noticed that in the description for the oil, it says multiple times that its for "racing only". Not sure why I couldn't run it on the street, just thought I'd try to get some more opinions before purchasing. Thanks.
Old Sep 12, 2012 | 07:11 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 20w-50 Valvoline Racing Oil okay for street?
It could work but i think that oil has fewer detergents in it compared to street oils. No big deal just change it more often.
Its really a heavy oil for looser bearing clearances. If you have a fresh motor with tight clearances you will be better off just using a good 30 weight oil
Old Sep 12, 2012 | 07:46 AM
Ranchopower's Avatar
http://www.enginebuildermag.com/Arti..._slippery.aspx
Old Sep 12, 2012 | 07:48 AM
I am using 5W20 racing oil in my street car, I use the AMSOIL brand.
I have tight clearences in my 351W
Javier
Old Sep 12, 2012 | 07:51 AM
Zaar's Avatar
Car: 1988 Iroc-Z tpi 5.7
Engine: ls2
Transmission: 4l80e
Axle/Gears: 3:42
its too heavy for your tolerances go lighter. first time it gets somewhat cold its gonna look like damn left over grease in a skillet lol!
Old Sep 12, 2012 | 10:00 AM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
So maybe the Valvoline 10w-30 VR1?
Old Sep 12, 2012 | 04:11 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
10W - 30 Sounds like a much better choice of weights. The 20W - 50 is OK in an older engine for hotter summer use.
Old Sep 12, 2012 | 04:47 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
What were your oil clearances set at by the machinist? Factory clearances are generally about .0015 with a fair amount of variance. If your engine was machined to OE specs it's probably about .0015 -.002 which is more for 30 weight or 10w-40. Race engines are generally set at .0025 for 40 weight or 20 w50. The issue with running too heavy oil is that not enough oil moves through the bearings to keep them cool. That and the valve train will starve for oil on every cold start.
I run 15w 50 Mobil 1 in my motor which was machined to .0025 (+/- .0001).
Old Sep 12, 2012 | 05:38 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Whats wrong with 5w30.
Old Sep 13, 2012 | 11:09 AM
91phoenix's Avatar
5W30 is another good choice especially if you will be running it in the colder weather like the northern states generally have during winter.
Old Sep 13, 2012 | 12:17 PM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
I don't remember the specs off of the top of my head, I'll have to see if I can dig up the build sheet.
I'm in Michigan, but the car won't be driven in the winter. Just from spring to fall, probably not in temperatures below 50 F.
Old Sep 13, 2012 | 01:19 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
You could try the 20w50. Just watch your oil pressure on cold start and listen to your valve train. You'll know it's too thick if the pressure spikes to 80 psi and the valves take a while to quiet down.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Gunsbee
Sep 7, 2015 07:10 PM
Amillionoh7
Sep 5, 2015 11:44 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
