73 nova help
Old Sep 15, 2012 | 04:15 PM
bypass-21's Avatar
Car: 1984 Trans Am
Engine: 305 cui
73 nova help
so i asked an unrelated question to my own F-body a while back, and the answers where so helpful and well informed i decided to try my luck again and see if you guy could lend me another hand
i took the head off my 73 6cyl nova since the head needed to be machined since it was warped, and blew the head gasket, but what i wanted to know were somethings i noticed on the block itself a few scratches, when i trag my nail on them i didint feel it, the one was made by me letting the head drag a little (since it was fairly heavy) and the other was mad by a razor when i was scraping the gasket off. i also noticed all the pistons were coverd in gunk, i took a razor to one of them to show how thick it was, i wanted to know what it is and what causes it so i can treat what ever it is effectively
[IMG][/IMG]
made with head ^
[IMG][/IMG]
made with razor
[IMG][/IMG]
DIRTY PISTON
thanks for any coments and help guys
Old Sep 15, 2012 | 04:39 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Re: 73 nova help
I wouldn't worry about the scratches.
The gunk is caused by years of oil and fuel mixing in there.
Also, have you checked out http://www.stevesnovasite.com ? That's probably the best resource I've found for Novas out there.
Old Sep 15, 2012 | 07:37 PM
bypass-21's Avatar
Car: 1984 Trans Am
Engine: 305 cui
Re: 73 nova help
thanks, i will be sure to check it out, and know that i know that the scratches are harmless i think i can sleep a little better tonight
and thanks for the sight ref i hope to get some good answers here and on there and see if i can fix some random stuff while i'm at
but what you said about the oil and gas in the combustion chamber, how do i clean it, and is it by wear and a part change, or is it normal
sorry to ask for more help
thanks again!
Old Sep 16, 2012 | 01:02 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: 73 nova help
just throw it back together and pretend you never saw anything..
if you want to clean the pistons, you trickle some water down thru the carb with it at a fast idle.. you want to dump just enough down there that it almost wants to die, but doesn't.. this will steam clean the chambers and piston tops and blow all the chunks of carbon out the exhaust.
Old Sep 16, 2012 | 01:26 AM
Car: '72 Chevy Nova
Transmission: TH350
Re: 73 nova help
Ya honestly that kind of gunk in there is normal for a stock engine from 40 years ago. If any oil drips in there from the valves or rings it'll gunk it up. You can use Seafoam to help clean it out after you rebuild it.
I've been a member on steves for awhile, they're very helpful. Good luck man
MyRedCamaro
Dec 29, 2015 05:16 AM
Jsharp16
Theoretical and Street Racing
Oct 29, 2001 08:54 AM
LowStyle
Oct 1, 2001 11:17 PM
SUPER-SPORT-CHEVY
Jun 27, 2001 10:51 AM
Metallica383
Sep 30, 2000 09:37 PM
