Let talk about this tbi issue
Old Sep 19, 2012 | 11:40 AM
albertgeorge1's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Ive found a few forums describing the same problem but no solutions. I am not one for playing the parts guessing game. So my 92 rs 305 tbi has a ver sporadic idle 200 to 1800 back and forth untill at op temp. When it is cold and the idle is bouncing around and you try to drive, when i push the peddle 1cm or WOT the car barely moves i just force it it and it accelerates so damn slow i mean like 3k on tach and im barely movin 10mph then all of a sudden it will take off like a bad outta hell. On colder mornings i have to drive for about 20min before it starts running right. This problem started the day after a 200mi rd trip. Since then ive replaced the IAC the o2 sensor the plug wires and plugs. Fuel press checked good so did the Injectors. I cant find any vacuum leaks and ive ran fuel cleaner through it as well. It threw code 44 the day after i replaced o2 sensor but the light was only on for maybe 20 min. So what else should i check and how? Also its been iddling about 2-300 rpm higher than usual in gear and in park. Car has 86,000mi on it all original
Old Sep 19, 2012 | 12:51 PM
ex-x-fire's Avatar
Re: Let talk about this tbi issue
Check the tps for smooth voltage increase.
Check cts at different temps w/ an ohm meter.
Check the grounds, esp. the ones on the back of the engine.
Old Sep 19, 2012 | 01:02 PM
Car: 92 Camaro RS
Engine: 305 TBI
Ok i will deffinatley do that and post what i find after work. Thanks !
Old Sep 19, 2012 | 05:23 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Definatly sounds like a sensor to me. Wouldnt suprise me if it was a MAF or IAC sensor
Old Sep 19, 2012 | 08:57 PM
Car: 92 Camaro RS
Engine: 305 TBI
i didnt get to test those but i have already replaced IAC and the other thing i just thought of was that my spark plugs showed no indication of the car running lean?
Old Sep 20, 2012 | 02:02 PM
Car: 92 Camaro RS
Engine: 305 TBI
I tested the tps and adjusted it accordingly. After i was done i was running it and finaly got it to act up in park while revving, the driver side injector didnt spray unless WOT. Should i replace the injector ? Or could another issue cause that?
Old Sep 20, 2012 | 05:42 PM
ex-x-fire's Avatar
Swap the injectors & see if the problem moves or stays at that side.
Old Sep 30, 2012 | 06:49 PM
Car: 92 Camaro RS
Engine: 305 TBI
Update. I changed the plugs and wires, didn fix anything. I bought a gasket kit at orielys for 25 bucks. I also replaced the driver side injector. I only replaced the top gasket the oring and injector on driver side. I also changed that red thing under that tense *** spring on the bottom of the tbi top. The problem has went away for now.
Old Sep 30, 2012 | 11:01 PM
Car: 92 Camaro RS
Engine: 305 TBI
Ok after driving my car 20 miles and filling it up, im having to crank it for a long time before it will fire off. Smells like running rich. Im thinking about changing the fuell pump. Any other ideas?
Old Oct 1, 2012 | 01:59 PM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
I'd replace the CTS ( there cheap) and check the ICM. Sounds like a temp sensor to me?
Old Oct 1, 2012 | 05:45 PM
ex-x-fire's Avatar
Check the injector spray pattern, should be a fine mist w/ no dripping.
Old Oct 1, 2012 | 07:55 PM
Car: 92 Camaro RS
Engine: 305 TBI
ok upon further reading and investigation i seen that the injector i just replaced was dripping. i took apart the top of the tbi again 1. i forgot the metal ring under the top Oring also i ripped the bottom 1 when putting it together yesterday i replaced the orings again and put the metal ring in, used some oil on the orings started right up no drips problem solved for now : ) next time ill look at the pics in the haynes instead of using it to hold down the box full of gaskets lol
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Dwayne614
Sep 28, 2015 08:33 AM
db057
Sep 4, 2015 07:57 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
