help my car has no spark
Old Sep 19, 2012 | 08:13 PM
doughtyrs92's Avatar
Car: 92 rs
I just bought a 92 rs 5.0 i had the fuel pump, engine coil, diode chip, replaced
it is like there is no spark going to the plugs it tries to turn over but it does nothing. the fuel pump comes on. any ideas what it is?
Old Sep 20, 2012 | 01:54 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: help my car has no spark
You need to install some spark. Lol. Seriously though, what is a diode chip? Do you mean the ignition control module? Or maybe the diodes in the alternator? First, perform a simple spark test. Since you already know you've got no spark to atleast one plug, start by checking for spark at the coil. If no spark there, use a 12v test light to check for signal at the white wire to the coil. First test with the test light's ground clamp on a good ground, you should get a bright flashing light as the engine cranks. Next try the test with the light's ground clamp connected to battery+. You should get a dim flashing light. If no flash, you have an issue in the distributor. If you just replaced the ICM, you may have a bad pick up coil or a poor connection. Of course, verify 12 volts at the pink wire to the coil and check all connections to the coil and distributor.
If you have spark at the coil look for a problem with the cap, rotor, or wires.
Old Sep 20, 2012 | 03:16 PM
Car: 92 rs
thanks
Old Sep 20, 2012 | 04:45 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Sorry for messing with you. Welcome to TGO. Still want to know what you mean by diode chip.
Old Sep 20, 2012 | 04:53 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I like to dip my diode chips in guacamole
Old Sep 21, 2012 | 09:10 AM
Car: 92 rs
not sure what the chip is my mechanic called it that said it might help but it didnt
Old Sep 21, 2012 | 11:56 AM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
Then your mechanic could be screwing you
Old Sep 21, 2012 | 07:55 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
lol i love all these "my mechanic told me it was my flux capacitor" stories.
Old Sep 22, 2012 | 08:45 AM
Car: 92 rs
thanks for the help and i got it to run the distributor was bad.
Old Sep 28, 2012 | 12:15 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
It is so funny that you said that. I am diagnosing an intermttent no start on a Delorean 1 today. I think it may need a new flux capacitor. LOL!
It's a Volvo with a wanna be cool looking stainless steel body. The car has the feel of a project that ran out of time and was rushed together at the last minute. BTW, don't ever buy one of these cars. They suck!
Old Sep 28, 2012 | 12:20 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Yeah. I kind of alluded to this in my first reply to you. The ICM is a common failure item. Unfortunately, just behind the ICM in failure rate, is the pick up coil. The test for this is a simple resistance test. To replace it though you need to tear down the dist. It's often better to just replace the dist as a whole. Glad your car is running again.
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
djmarch
Aug 9, 2015 05:27 PM
