Vortec heads Max lift
Car: 1991 Z28
Engine: 5.7L
Hey everyone, i am new here. I also looked through some of the older threads to see if anyone had any information that could help satisfy my ideas. And if i am asking a question that someone has already posted and answered i apologize in advance and hell- maybe someone can point me in the right direction then. Currently i have a 1991 Z28 (it has not ran or moved for 7 years- kids will do that to you
) I have been working on it here and there and finally i am down to planning my build. I have seen from many others on here that the Vortec HSR intake is a good combo with the vortec heads that GM makes. I have decided to go this route, my only reserve is that when it comes down to the cam i pair them up right. I am looking at the GM part number 12558060 (taken off the heads) they are cast iron heads:
170cc Intake Ports
64cc Combustion Chambers
1.940'' Int/1.500'' Exh Valves
.475'' Max Lift
Those are the specs. I am pairing these heads with a LT4 Hotcam- Imagine that.... lol i see that there are alot of people doing that so i am sure that it is possible .525 .525 with 1.6 rocker arms.. I want to know what modifications to the head aside from the obvious springs would be needed to ensure this combo works minimizing the chance of damage.. I am after details on what machining will be needed if aside from springs if any at all. I need some good feedback and some ideas. I happen to have a set of these heads laying around and a hot cam that i aquired from a wrecked 4th gen (LT1 motor- I knew the owner) that was getting junked.. Anyways, like i said if i am in the wrong place and someone has already posted a thread that will answer my questions then please point me in the right direction, if not the fire away i am open to new ideas and suggestions. Thanks
) I have been working on it here and there and finally i am down to planning my build. I have seen from many others on here that the Vortec HSR intake is a good combo with the vortec heads that GM makes. I have decided to go this route, my only reserve is that when it comes down to the cam i pair them up right. I am looking at the GM part number 12558060 (taken off the heads) they are cast iron heads:170cc Intake Ports
.475'' Max Lift
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
Re: Vortec heads Max lift
Take them to your local machine shop. I know for starters they need set up for screw in studs.
Car: 1984 camaro z28
Engine: sbc 383
Transmission: Th400
Axle/Gears: Moser 9", 4.11 gear
Having your guides cut will be an easier route, but you can also check out a place called Alex's parts. They have some vortec springs that can allow up to .550" lift. I am running these springs with a .540" lift camshaft. I have heard others also choosing this route and not having any issues. But as mentioned above, screw in studs are recommended and at that point should get your guides cut as well.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Since you dont have the heads installed, I would go ahead and get the guides cut and screw in studs installed.
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
I installed CHE bronze guides on my vortecs. Im running .563"/.578" lift with zero troubles.
Engine: sbc 383
Transmission: Th400
Car: 82 Z28
Transmission: T400
I just reworked a set of vortecs. I used Comp springs (#26918) #787 retainers, and Crane +.050 valve locks. This allowed me to get VERY close to the recommended 1.80" installed height(1.795"), This combo gave me .590-.600 retainer to seal clearance, for a safe .550 lift. No valve guide machining necessary. I DID, however, get the threaded rocker studs installed. There are some minor variances between heads, of course.
Engine: sbc 383
Transmission: Th400
I appreciate the charts, and actually what you said was a very common response i got before i put the camshaft in my car which at one point almost swayed me not to run the setup i have now. But i would also have to disagree with you. My heads are not ported, and i ran 12.97 with a .490" lift camshaft and 11.91 with .540" lift cam. I'm going 100% off of what i personally have experienced. There are plenty of people who also vouch for the lift of vortec heads actually being better up to about .550" where at that point they do to taper off pretty drastically. But then again i'm sure there are people who experience the opposite. I'm no professional on vortec heads, i just know what personally worked for me.
Car: 1986 Iroc-z Camaro t-top
Engine: 355 SBC
Transmission: 700r4 TCI const. Pres. Valve body
Axle/Gears: 3.73 posi/mosuer axles
Car: 87 iroc-z
Engine: 454
Transmission: th350
heres a good read on vortecs.
http://www.chevyhiperformance.com/te...t/viewall.html
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
