Starting problem help?
Old Oct 5, 2012 | 02:01 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I have been having a couple of problems with my car and been fixing them little by little but this problem has me stuck. I have to spray starting fluid for it could start up but once it starts it runs good. Could it be my fpr?
Old Oct 5, 2012 | 06:05 AM
ex-x-fire's Avatar
Re: Starting problem help?
Alittle info on what you've got goes a long way. Year? Efi or carb? Ect.
Old Oct 5, 2012 | 03:41 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Sorry about that i have a 91 305tpi. Oh and the car hasn't been driving for over 5 yrs as well.
Old Oct 6, 2012 | 12:51 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Bad, (old), gas.
Old Oct 6, 2012 | 02:39 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
i already poured fresh full tank of gas after i replaced the pump with new strainer as well and still same problem. Now my fuel pump is getting no current to it.
Old Oct 11, 2012 | 02:29 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
OK so i hooked up a fuel pressure gauge and get no pressure at when i crank it.
Old Oct 11, 2012 | 02:35 PM
speeddemon86z28's Avatar
Car: 86 Iroc-Z, 92 Firebird Formula
Engine: 350 carb, 305 TPI
Transmission: T5, T5
How long will it stay running when you use starting fluid? Did you hook your fuel pump up correctly?
Old Oct 11, 2012 | 02:43 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Once it starts it runs okay. It just needs like a little fuel boost.
Old Oct 11, 2012 | 03:23 PM
So, your saying your car runs with no fuel pressure? Either i'm crazy...or something doesn't add up here.
Old Oct 11, 2012 | 03:45 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
That is what has me stuck. I ain't sure if its my fuel pressure gauge that aint working or what.
Old Oct 11, 2012 | 06:22 PM
Hook the fuel pressure gauge up to it and then get it running and see what it says...you said the car has been sitting for awhile, it may just need a simple tune up.
Old Oct 11, 2012 | 06:49 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
When?
Pump only primes for 2 sec when key turned on then turns off so you will see no power to the pump after the initial 2 sec burst
Putting 12V to terminal G of the ALDL connector will make pump run fulltime for testing purposes
Check your oil pressure switch is connected and working.
Should make the pump run independent of the computer operated pump relay as soon as engine has 4 psi OP
jumpering the OP switch connector should make the pump run ( to confirm not a wiring problem )
Old Oct 11, 2012 | 07:41 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Well i got my pump to work now. It was a wire loose from my alarm system. Now i think i don't have sufficient fuel pressure to start up the car because i have to spray starting fluid everytime.
Old Oct 12, 2012 | 12:46 AM
You could do what vette said, if you understand him correctly. Or you could get it running by using starter fluid and have the fuel pressure tester hooked up. That would tell you whether or not you have sufficient fuel pressure. Figure out your fuel pressure with the car running and get back to us.
Old Oct 13, 2012 | 01:09 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Just did that today and my fuel pressure is 35-40psi. My neighbor told me to check my spark plugs so i am going to try that tommorow too.
Old Oct 16, 2012 | 12:51 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
OK well now my fuel pump is working correcty. But i still have to spray the starting fluid to start up my car. Could it be because I dont have the intake connected I have the MAP sensor 91-92 tpi.
Old Feb 20, 2013 | 04:04 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Ok well still have this problem now i found out my problem i hooked up a scanner to it and noticed my fuel pump doesnt get any voltage when i flip the key to on position. But when i start cranking it gets 10 volts only. I checked my relay its good also my fuse is this a common problem on this?
Old Feb 23, 2013 | 09:26 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
vetteoz so if i put 12v to the g the pump should turn on right?
Old Feb 24, 2013 | 05:18 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Correct ( assuming the relay is good )
Probably about right considering the starter is sucking alot of power from the battery .The voltage you see there is probably from the OP switch
Can disconnect the relay and see if you get the same voltage to confirm the switch is working correctly.
Something is wrong because if you have enough fuel pressure to run the engine then you should have enough to start it.
Possibly your injectors are not being fired while cranking over? Have you got a noid light to check for injector pulses when cranking?
Could it be because I dont have the intake connected .
Old Feb 24, 2013 | 07:06 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
ok well today i did what you recommended what you said put 12v to the g terminal and the fuel pump did run
im starting to think its not the injectors firing up at the beginning and no i dont have noid lights is there any other way i can find out?
Old Feb 25, 2013 | 11:54 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
OK well today i got some noid lights and found out my problem. Only one side of my engine injectors fire the other side doesnt at all none of them. All of the driver side injectors when i put the noid light would flicker but when i put it onto the passenger side injector plugs none of them flickered could this be a ground?
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
