Stock RS faster than stock Iroc, why?
Old Oct 12, 2012 | 01:00 PM
robjonez's Avatar
I own a 1992 rs 305 TBI. I just picked up another camaro. It's a 1990 iroc 305 TPI. It has 103k miles on it. Seems to run fine. But it is very noticably slow than my 92 rs. The previous owner had all new injectors installed. Other than that nothing else has been done. Any help on where to start to find out why I'm not getting the HP would be great.
Old Oct 12, 2012 | 02:05 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: Stock RS faster than stock Iroc, why?
What's noticably slow? Have you run them side by side?
Old Oct 12, 2012 | 02:11 PM
robjonez's Avatar
Yes I've had them side by side. And the iroc just doesn't feel as peppy as it should be. Feels like slow acceleration.
Old Oct 12, 2012 | 03:47 PM
red rock's Avatar
Car: 1987 iroc
Wonder what injectors the PO installed? Should be 19lb. Also, maybe the timing needs adjusting on the TPI.https://www.thirdgen.org/settingtiming Tune-up with new plugs, cap, rotor, wires if needed, can perk up a car also.
Old Oct 12, 2012 | 04:06 PM
robjonez's Avatar
Yeah I just pulled a plug its a little white. I don't know about the injectors. Who ever put the in wrote with a sharpie numbers on the top of TPI system. I also can hear a wierd ping or knock, not the sound of a vaule or lifter makes but different.
Old Oct 12, 2012 | 04:25 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Check the timing. it may be advanced too much and causing knocking and thus making you lose power...
Old Oct 12, 2012 | 04:37 PM
robjonez's Avatar
Yeah I'm going put a timing light a see what happens. Thanks for the input, greatly appreciated.
Old Oct 12, 2012 | 08:00 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
The gears the same?
Old Oct 12, 2012 | 08:44 PM
red rock's Avatar
Car: 1987 iroc
Originally Posted by FtrSpeedy
The gears the same?
Gears should be the same. If your plug is white, your running lean.
Grant2k
Jul 10, 2018 04:01 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mustangman65_79
Aug 12, 2015 06:39 AM
mustangman65_79
Aug 11, 2015 03:17 PM
stalkier
Aug 7, 2015 04:49 AM
