camaro have egr valve?
Old Oct 12, 2012 | 09:14 PM
Ridngchoppers's Avatar
Car: 86 chevy 28 camaro
Engine: 305 tpi
my scanner came up with a bad egr solenoid #3 ? is that a valve?
Old Oct 12, 2012 | 09:15 PM
Engine: 305 tpi
Re: camaro have egr valve?
i have a 86 z28 with a 305 tpi
Old Oct 25, 2012 | 05:25 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Silly Solenoid
It’s an electromagnet which controls a valve.
The scanner is detecting an electrical problem on the electrical portion of that assembly.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Old Oct 25, 2012 | 07:02 PM
perschken's Avatar
Car: 91 Firebir Formula
Egr solenoid I believe is back by the distributor and mounted to the coil bracket. If you follow the vaccum line off the egr valve (under the plenum) you will find it.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
