Great torque in 1st 2nd 3rd but bogs out & no torque in 4TH(OD) 700r4 & 350
Old Oct 16, 2012 | 04:37 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
Engine: 350 ATK Performance
Axle/Gears: Eaton 3.73
I will fully accelerate my car and it will shift smooth 1,2,3rd and I will keep the pedal down and shift to 4th(OD) I have no power at all. It will be at high RPMs then in 4th it goes to like 1900-2000rpms. It bogs and the wide-band reads lean air/fuel(Auto-Meter light show). I checked my distributor cap and its still tight, new spark plugs with correct gap, #24 injectors(WITHOUT TUNE)
I downsized injectors because I had #30s from when my car was supercharged.
Motor: 350 crate from ATK Performance, stock TPI, 52mm BBK TB
Transmission: 700r4 Built
Rear end: 3.73 Eaton posi
I would think my bad tune is causing this but it did it for my #30 injectors also.
Old Oct 16, 2012 | 05:19 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Great torque in 1st 2nd 3rd but bogs out & no torque in 4TH(OD) 700r4 & 350
Originally Posted by neeb_usmc
It will be at high RPMs then in 4th it goes to like 1900-2000rpms..
What do you expect ?
O/d is for fuel economy and cruising ; not accel
The 70% reduction O/d ratio kills torque, engine is only turning 700rpm for every 1000 rpm of trans
You make torque when a engine is geared down like in 1st gear were engine does 3070 rpm to 1000 rpm @trans
Old Oct 16, 2012 | 05:29 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
I realize that it is for cruising but it never would bog down like Im letting off the gas when I still have the pedal down. Wondering if my torque convertor is jacked up
Old Oct 16, 2012 | 06:17 PM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Yeah that's not normal, my stock lt1 pulls 4th pretty hard up to 140mph. Seeing how you have 3.73 gears and a 383 yours would pull 4th better then that.
Old Oct 16, 2012 | 06:21 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
correction it has a 350 now. Wonder if its Valve body or torque convertor?
Old Oct 16, 2012 | 06:29 PM
89rs454's Avatar
Car: 1989 SS
Maybe your converter is locking up in 4th gear at wot?
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
dhonda200
Aug 11, 2015 11:50 PM
