High Idle 86 TA 305 TPI
Old Oct 19, 2012 | 07:28 AM
wehrlebird's Avatar
Car: 87 T/A
Engine: 383
Axle/Gears: 373
I looked through other threads for about a half hour and didn't see anyone with this problem.
I set my TPS to .54V, then set my IAC. It idles fine at about 800RPM. When I shut the card down and restart it, it runs up to 1800 RPM and then comes back down after a few seconds to 1000 RPM. Drop it in gear the idle drops to about 600 RPM and then you can feel the IAC take over and the engine is trying to accelerate. If I put it in Neutral or Park the idle immediately goes up to 1800 RPM then after a few seconds comes back down to 1000 RPM. It seams that by shutting the car off it's reseting something and it doesn't like idling at below 1000 RPM so the IAC is trying to compensate. If you try to drive the car it is constantly pushing you down the road not to mention hard on the brakes.
Any ideas?? This is driving me nuts.
Old Oct 19, 2012 | 09:15 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: High Idle 86 TA 305 TPI
Have you checked/verified that there are no vacuum leaks? Your idle should be around 850-900 in park, 600 in gear.
Old Oct 19, 2012 | 09:26 AM
wehrlebird's Avatar
Car: 87 T/A
Engine: 383
Axle/Gears: 373
Yes, no vacuum leaks. After I set the IAC, I start the car up again and it runs great, no idle problems at all until I turn the car off and restart again. From that point on it's always running high.
Old Oct 19, 2012 | 09:56 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Is your choke out of adjustment? Are you sure you're not runing a bit lean?
Old Oct 19, 2012 | 10:01 AM
wehrlebird's Avatar
Car: 87 T/A
Engine: 383
Axle/Gears: 373
No choke. TPI - Tuned Port Injection.
Old Oct 19, 2012 | 01:41 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Wow, my bad, I read that as "TBI"....
Old Oct 19, 2012 | 01:53 PM
wehrlebird's Avatar
Car: 87 T/A
Engine: 383
Axle/Gears: 373
No problem Ozz
Old Jul 25, 2018 | 02:26 PM
BlksIrocZ's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI L98
Transmission: 700R4 Auto.
Did you ever resolve the high idle issue?
Old Jul 25, 2018 | 03:07 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
check no. 3 Diagnostic aids.This is from the 86 Firebird Service Manual.
I'm betting it's a vacuum leak.
Old Jul 25, 2018 | 07:23 PM
BlksIrocZ's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI L98
I have the manual as well. I have checked every vacuum leak possible. My car idles at 100-1200rpm in park or neutral but is fine in drive.
Out of diagnostic aids the only things I have not checked is AC clutch loads (My AC has been deleted years ago), and AIR management system. How do I check these? Never checked injectors either but it drives fine. High idle is very very irritating though.
Old Jul 28, 2018 | 03:49 AM
Jon Hillis's Avatar
I have an 89 Camaro 5.0 tbi with a very high idle. I changed all the vacuum lines, replaced tps, replaced aic, put all new gaskets on tbi. Still running high idle about 1600! I've seen a ton of videos on how to adjust the tps but mine cannot adjust, it does not move like the other tps' that I've seen. My engine is a vin type E. Please help!
Old Oct 10, 2018 | 11:27 AM
CAM-Z's Avatar
I have an 86 Iroc with a 305 tpi and I’m having the same issue, when I first start the car it idles fine in Park, then drops in drive, but after I’ve gone for a drive and put it back in park it will idle at 1500rpm, similarly if I put the car in neutral it won’t drop the rpm will raise to 1500. I’ve replaced the vacuum lines, checked for intake gasket leaks, tps iac and maf have been replaced and set as well. Please help
Old Oct 10, 2018 | 01:14 PM
GeneralDisorder's Avatar
What is the readout from the coolant temp sensor (CTS)? Not the gauge on the dash - the sensor for the computer. The computer may be using a high idle because it thinks the engine is colder than it actually is. If you don't want to troubleshoot with Visa, you are going to need to acquire the equipment to read live data from the ECM. You can test the CTS for resistance and compare to a chart but that still doesn't tell you what the ECM is seeing on the other end of the harness, etc. And it could be something else entirely. That's just a shot in the dark.
GD
Old Oct 22, 2018 | 01:03 PM
86IROC112's Avatar
Car: 1986 IROC Z
GD
I'm having a similar problem nobody can seem to figure out. Car idles high until it warms up. When connected to Tuner Pro it read the coolant temp at 80 degrees upon first start up which would have been about right since the car was parked in the garage during the summer. The ECM's target RPM is 800 but it still idles at 1500 for a bit then drops to 1250 until the engine is good and warm, then it idles normally. It always seems to really kick down to the proper RPM when it's in gear sitting at a stop sign or red light. You can literally feel the AIC close to drop the idle. The car runs so damn good with the annoying exception of this...Been two years and I can't figure it out. No vacuum leaks, TPS, AIC, all that stuff has been adjusted and triple checked... Driving me nuts..
Old Oct 22, 2018 | 04:01 PM
When you are in warmup under open loop the target idle RPM is not used. That is only used when in closed loop idle and once it reaches a specified minimum coolant temp. Prior to that it's going to use something like an IAC steps vs. Coolant Temp table or some such. You'll have to check your BIN for warmup idle settings. It is NOT the warm target idle setting. And yes when you drop it in gear the idle will change because of the load from the torque converter, etc.
GD
Old Oct 22, 2018 | 05:01 PM
86IROC112's Avatar
Car: 1986 IROC Z
GD
I'm no expert but the car is not in open loop for 10+ minutes is it? When it does kick down in gear it's idling at 1000 or so then magically drops to 600. It's really weird.
Old Oct 22, 2018 | 05:30 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Old Oct 22, 2018 | 05:32 PM
Engine: Lb9
Transmission: M20
Here is what the eco should be doing based off coolant temp. I’m wondering if a heated o2 might help you. I’m really confused why your car does this. Closed loop will happen with the engine temp is 77.45f and the o2 is at 500 to 600 degrees f.
Old Oct 22, 2018 | 11:15 PM
Could be running rich and the O2 is taking a long tims to get up to temp. Have you monitored open/closed loop status?
Old Oct 23, 2018 | 10:41 AM
Engine: Lb9
Transmission: M20
I have looked at datalogs but don’t see anything abnormal.
Old Oct 23, 2018 | 12:31 PM
86IROC112's Avatar
Car: 1986 IROC Z
What is a heated O2?
Old Oct 23, 2018 | 12:36 PM
An 02 sensor with a heater in it. AKA - "Three-wire O2". You wire it up with switched power and ground in addition to the signal lead and it heats up faster.
GD
Old Oct 23, 2018 | 12:37 PM
Engine: Lb9
Transmission: M20
Old Oct 23, 2018 | 12:52 PM
86IROC112's Avatar
Car: 1986 IROC Z
So it's possible it's staying in open loop for this long? Worth a shot I guess...
Old Oct 23, 2018 | 01:06 PM
Engine: Lb9
Transmission: M20
I think it might take 10-15 min to get the o2 active. This is a issue with headers which I forget it you have them or not.
it might speed up your issue from happening I’m really out of ideas.
Old Oct 23, 2018 | 02:01 PM
86IROC112's Avatar
Car: 1986 IROC Z
That's about exactly the time it takes to kick down. After work I have been starting the car then going downstairs to change. By the time I get back out to the car it is idling better. I am running stock manifolds but this sounds like it's worth a shot.
Old Oct 23, 2018 | 02:54 PM
Yeah I doubt that's going to fix it. I DO have headers and a stock single wire sensor and mine does not act like that. I have the exact same car but I'm running '89 $6E modified BIN for CSI delete, and 24 lb Bosch III's.
89 BIN's that don't use the CSI have much better programming - if you haven't done that I would upgrade the microcode before I wired in a heated O2. Not that it's going to hurt anything and yes it would warm up faster but I don't see it solving this problem.
GD
Old Oct 23, 2018 | 04:23 PM
86IROC112's Avatar
Car: 1986 IROC Z
GD
Tuned Performance burned a chip for me and I believe it's an 89 program. He could verify that though...I hate throwing parts at a car but I'm willing to try anything to solve this problem...
Old Oct 23, 2018 | 04:34 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
when I had a TPI my throttle body shaft was worn out creating a vacuum leak with symptoms very similar to these. occassionally would idle at around 1500 causing it to pull while i was at a stop light, if I blipped the throttle it would go back to its correct idle.
Old Oct 23, 2018 | 05:10 PM
Engine: Lb9
Transmission: M20
He’s running $6e , The issue was there with $32 mask as well. He has also tried another ecm and still no luck.
Old Oct 23, 2018 | 06:09 PM
You have deleted the CSI?
Old Oct 23, 2018 | 06:12 PM
Engine: Lb9
Transmission: M20
Here is another thread with his issues
https://www.thirdgen.org/forums/tpi/...high-idle.html
im not sure the csi would make a high idle. The timer switch is ran off power from the starter solenoid wire so cold start fuel is not for a very long time seconds I think based on cranking and the engine temp. Warm I think the switch is open.
Old Oct 23, 2018 | 07:26 PM
True - probably not related. Maybe he should consider a smoke test of the induction system? A vacuum leak could cause idling issues for sure. The system would learn around it to a degree. Has he checked his BLM's? Has he checked how long till it goes into closed loop?
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
