1989 IROC not running right
Old Nov 4, 2012 | 03:10 AM
tdnile's Avatar
Hopefully someone can help. I have a 1989 IROC with the 5.0 TPI eng in it. Here is my problem: The car starts up and idles for a few min. and starts surging, the car acts like the fuel is being cut off. The distributor cap,plugs and wires have been changed. The car has never have a new fuel pump or filter since I've owned it, and I have put over 100,000 miles on it (it has over 200,000 total). Any help would be appreciated.
Old Nov 4, 2012 | 09:08 AM
89G92CAMARO's Avatar
Car: 89 CHEVROLET CAMARO IROC-Z G92 CPE
Engine: LB9 305 TPI V8, DUAL CATS, HUGE CAM
Transmission: T-5 SPEED
Axle/Gears: 9 BOLT BORG WARNER/3.45 RATIO
Re: 1989 IROC not running right
I have that same problem. Mine does it when it's warm. But, it would still do it whether cold or warm. I have changed all of those things as well. Also I changed the Fuel Filter. It could be the Ignition Control Module and the In Gas Tank Fuel Pump. I will be changing those two things as well. Try and check your MAF System. If this doesn't solve the problem it could be your Fuel Injectors if they are still the original Multec Injectors. If that happens to mine, I will be changing them to the Bosch III injectors which everyone is running. Hope this helps.
Old Nov 30, 2012 | 09:46 PM
Ashton89iroc's Avatar
Car: 1987 IROC-Z
Engine: Vortec 350 crate #12530282
Transmission: 700-r4 Auto
i had the exact same problem when i bought my 89 iroc. turned out to be a combo of bad injectors (main problem) cap and rotor, coil, plugs and wires....the basics. definitely take a look at those injectors though.
camaro11j
Sep 19, 2018 08:49 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Rustyweb7
Aug 9, 2015 03:05 AM
