Which to get:Intake or Cam?
Old Nov 12, 2012 | 12:16 PM
Guest
Guest
Posts: n/a
Hey guys just wanted your opinions on something. If I could get either an HSR setup(intake and fuel rails) or a cam kit(cam and lifters) but not both for Christmas, which should I go for? I'm not concerned with price differences so don't throw those into the equation. I will eventually get both but which would be the best to start with on a stock L98 running only exhaust right now? And which cam would you guys recommend, staying with a hydraulic roller cam? Going to be very mild and probably be done with mods to the engine after the intake and cam. I have been looking at the Super L98 cam, any thoughts? Thanks fellas!
Old Nov 12, 2012 | 08:20 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: Which to get:Intake or Cam?
Intake. A cam will not make more power if it can't breathe.. if anything, you might lose power if you do not provide the modifications necessary that the new camshaft profile is designed for unless it's a regrind of similar specs to what you already have (which IMO is a massive waste of money since you have no idea what you want to do later). Getting an intake by itself won't give you the full effect, though. I'd suggest a good exhaust before the intake because it's equally important to push the exhaust out as it is getting more air. It's about the whole 'package' and not just parts of it.
It's kind of like (hypothetically) asking for bigger lungs and still having a small heart that can't support them. Doesn't make a whole lot of sense.
Old Nov 12, 2012 | 08:46 PM
Guest
Guest
Posts: n/a
I have full 3 inch exhaust no cats
Old Nov 12, 2012 | 08:47 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Pretty obvious no-brainer then. Get the intake.
Old Nov 13, 2012 | 07:45 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
For sure man, pick up the HSR! It'll support all the future mods you want.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
