lots of smoke
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
lots of smoke
i just got an 89 iroc, smokes a lot on start up like the stem seals are bad and stops when you drive a little still seeming like the valve stem seals ... but on start up it idles around 2000 rpm until it warms up a lot (longer than any other car i have had) and when parked if you pull the throttle it smokes out the back of the motor and the pipes, i cant see where the smoke in the engine compartment is coming from yet, but was told it had a "vacuum leak code" ... it runs and drives good, but what i would like to know, is there any way all these things could be coming from a bad intake gasket ... need all the help i can get, thank you
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: lots of smoke
Re: lots of smoke
its not a little smoke, and the smoke from the back of the motor seems to blow around (without the fan on) pulled the hose from the valve cover to the breather and no smoke out of it (so it didn't seem like massive blow by) it seems to blow smoke when vacuum is pulling and the car is not moving
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
Re: lots of smoke
this will sound stupid. my friends car had an oil leak , so he used to ad a qt a week never checking the level , a month later all kinds of smoke , so it must need more oil rite? 2 qts later the car would bearly run oil all over the driveway . oh its leakink bad now , more oil . car wont start ,motor siezed no good I bought the car for 200 drained about 15 qts of oil and filled to proper capacity started hard ran and smoked for 1/2 hr cleard up and ran perfect . I guess I'm saying check your oil level .
Re: lots of smoke
i wish it was just the oil, i checked it when i got it (it was about 1/2 quart low), guess i will just have to wait till i get the money to pull it and rebuild it ... just hate to rebuild a 305 tbi, but going to keep it numbers matching for my son, if i can keep it alive ror 14 more years ... lol
Car: 1990 z28
Engine: 5.0
Re: lots of smoke
ck the smog components somebody else had a similar problem it was some kind of sensor by the vac canister . that may explain the vac leak code as well. while its running disconect the vac line at the canister check for smoke . be aware it will run like crap with this line disconected . so limit the time its unpluged .
Car: 90 Iroc Vert
Engine: 5.0L
Re: lots of smoke
My car smoked bad (out the exhaust) 89 350 TPI
replace valve seals and valve springs - most were broke (springs)
no more smoke.
Not sure where under hood would come from other than a oil leak or exhaust leak.
no more smoke.
Re: lots of smoke
ok, ill check that, and as for the seals and springs, ill have to wait for that, its cold outside, and i am broke until taxes come in ... thank you all for your time, and ill be checking back here often for any other thoughts on the matter
Re: lots of smoke
anyone ever changed valve springs with the heads on? will the springs compress enough to get the retainers on with the pistons holding the valves up, or will i have to make something to go through the plug hole to hold them up?
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: lots of smoke
Apply air pressure through the spark plug hole to keep the valves from falling in. Both valves must be closed before applying pressure.
Engine: 4++,350 & 305 CIs
Re: lots of smoke
I was in Mattoon last weekend.
fix valve seals, maybe new springs while your in there?
I would also check the oil drainback holes in the back of the head for being full of gunk
Change your valve cover gaskets.
Is the rear intake leaking?
Leaking oil sending unit?
You will get lots of guesses here, best is to go out and look for the leak thats making smoke.
Car: 88' IROCZ
Axle/Gears: 2.77
Re: lots of smoke
My apologies, but you didn't specifically ask for an alternative to compressed air. You can get a small portable 250 psi 12v compressor, or 1 to 3 gallon compressors for less than $100 at Walmart, might even get a better deal at a pawn shop. To own these cars is to have money not just for repairs, but for performance as well.
Re: lots of smoke
Re: lots of smoke
You can also use a small nylon rope in the cyl if your careful.
remove neg batt cable
remove rocker/valve covers
pull spark plug.
rotate motor to BDC
remove rocker arms of cyl your working on
install some nylon rope in sparkplug hole and leave plenty out so you can remove rope later
very very carefully rotate motor till you feel it stop
R&R springs and seals.
Now go in reverse order to finish that cyl
move on to the next one
pull spark plug.
rotate motor to BDC
Re: lots of smoke
pull spark plug.
rotate motor to BDC
pull spark plug.
rotate motor to BDC
