engine mount block half which way around??
Old Jan 14, 2013 | 06:43 PM
bad to be blown's Avatar
Car: 89 gta
Engine: 5.7 supercharged
hi guys just rebuilding my 350 from my trans am, full rebuild and spraying everything like new
just redone the top half of the engine mounts that bolt on to the block but i dont know which way around they go on the block. ones deeper then the other.
thanks for the help in advance
bad
Old Jan 14, 2013 | 09:51 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: engine mount block half which way around??
i'm prepping an engine for install right now . i also would like to know . good luck .
Old Jan 15, 2013 | 03:35 AM
Car: 89 gta
Just couldn't tell there was a difference intil I was cleaning the rust of them
Been looking at some old photos of my car but just can't see them
Bad
Old Jan 15, 2013 | 03:46 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I cant find it but maybe you can. I remember reading that there are part numbers on the clamshells, the one with an odd number at the end goes on one side, and even number goes on the other. Just cant remember which side but maybe if you search for something along those lines you'll find it.
Old Jan 15, 2013 | 03:54 AM
Car: 89 gta
yeah i had seen the part numbers but dint think to search for them good idea i like it
is that what there called? clam shells???
thanks
bad
Old Jan 15, 2013 | 04:10 AM
Car: 89 gta
i found this so far, on this topic page may help if its correct
https://www.thirdgen.org/forums/newr...eply&p=4923789
Originally Posted by LS4GXP
Yes you are correct, it moves the motor left to right about 1/2 inch. The passenger side mount is 039436. Driver side is a longer number, dont know it off the top of my head.
I would think any bolt would be fine aslong as its a heavy grade bolt and fits the hole
Old Jan 15, 2013 | 04:27 AM
Car: 89 gta
another useful page
https://www.thirdgen.org/forums/engi...de-engine.html
agreeing with the other post so im going to go with that my self
passenger side 14039436
drivers side 334970
jhawkeye
May 25, 2022 06:33 PM
Infested
May 22, 2018 11:56 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
