Performer intake 25 hp gain on L69?
Old Jan 2, 2013 | 10:55 AM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
http://www.darklair.com/monte/L69.buildup.html
I came across this on a Monte Carlo website. They are apparently saying that you can expect a 25 hp gain on the Edlebrock performer intake....
I know there are dissenting views of this, but I think that if you are running aftermarket exhaust and hooker headers, etc. then the increase in power with the performer intake over the stock intake may be the result of the cumulative effect of the exhaust / header combo...
If this is true, then for $150 for a 25hp gain is quite a bargain...hmmm
Is the monte carlo L69's stock intake the same as the f-body L69 stock intake manifold?
Old Jan 2, 2013 | 11:13 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Performer intake 25 hp gain on L69?
I wouldn't attribute the whole 25 HP to the intake.
The Performer is pretty similar to the stock intake.
Old Jan 2, 2013 | 03:06 PM
Chuck84TA's Avatar
So is it safe to assume that there is a certain amount of performance "synergies" that are needed to see the 25 hp that they are claiming,...... or is it the fact that the Monte Carlo L69's have a less than capable intake manifold than the "f" bodies that we know and love?
Old Jan 2, 2013 | 03:07 PM
Chuck84TA's Avatar
Or is it just ...... A false claim?
Old Jan 3, 2013 | 12:23 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They both have the same intake.
The link says they put on the intake and did a "timing change" for the second run. Without knowing the before and after details for the timing you can't say anything about the intake alone.
Old Jan 3, 2013 | 04:11 PM
Chuck84TA's Avatar
Interesting ...Thanks for the feedback Aperion.
Old Jan 10, 2013 | 02:48 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I can however tell you that I put a performer RPM on a 305 in my G series van. The engine had a generic 204/214 @ .050 cam in it, doug thorley tri-Y headers, and exhaust. I had the aluminum Q-Jet factory intake on it with the factory Q-Jet, replaced the factory intake with the performer RPM and it was a very noticeable difference even with the same Q-Jet and 10* initial timing I was running.
Old Jan 10, 2013 | 03:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A Performer RPM is a decent upgrade over stock.
DJanes97
Sep 1, 2015 02:55 PM
ambainb
Aug 29, 2015 12:43 AM
midias
Aug 22, 2015 01:42 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
