how do i bypass vats
Old Mar 2, 2015 | 10:22 AM
  #51
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: how do i bypass vats
Originally Posted by Freakazoid
Yes I was thanking you for that info.
Old Mar 6, 2015 | 11:16 PM
  #52
taylor1992's Avatar
Hi i have a 92 camaro rs 305tbi auto Trans .. I too have a question on what to do when you have done the bypass trick with the correct resistance. My has has been running on the bypass for roughly a year .. every now and then the car would choose when it wanted to start and when it wouldn't .. sometimes the car wouldn't start and then I would sit there for 10 minutes and it would and wouldn't have an issue for roughly a week .. today it pee'd the bed and did this for 45 minutes and then started .. so I figured it would be alright to shut it off one last time to get food and sure enough it won't start .. lucky my friend has a flatbed .. where should I go from here ? Can resistors go bad or is it my vats module going bad ? Also to bypass completely you need a new chip burned if I remember right from reading on this page so if anyone knows anyone on here or a shop I need to fix this asap for work lmk thank you !
Old Mar 29, 2015 | 11:53 AM
  #53
crzymike's Avatar
I would first check were you connected the resistor for signs of corrosion. I did have a resistor break( the wire from the blue section of reistor broke off) in the past.
Old Apr 5, 2015 | 01:21 PM
  #54
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
does anyone have a picture of where to connect the resistors at the column under the dash.?
Old Apr 5, 2015 | 01:49 PM
  #55
Engine: Lb9
Transmission: M20
junior419
Apr 7, 2025 11:35 AM
$750 L98
Feb 1, 2025 02:25 PM
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
Racerx974
Sep 19, 2015 10:16 AM
