Distributor swap
Old Jan 5, 2013 | 05:15 PM
zzjakect's Avatar
Car: 1985 Z28
Distributor swap
I want to change the distributor in a 1985 Camaro 350 TPI. Can anyone suggest a good product? What is the advantage of an aftermarket product over original equipment? Also are any special tools required? Any tips would be appreciated.
Old Jan 5, 2013 | 06:14 PM
Re: Distributor swap
http://www.summitracing.com/parts/du...make/chevrolet
I think...
The early years of TPI used a different cap, had to be shorter to fit down under that little cover. Give em a call and see if this one has that.
No special tools. Short 9/16" combo wrench.
I'd suggest bumping the motor over to #1 firing position (make sure it's the FIRING instance of #1 TDC, and not the EC/IO instance); raise the existing dist straight up out of there, making a note of exactly where the body was turned; hold the new one with the body the same as the old one, and turn the rotor to macth; drop it in; tweeek it as required to get the star wheel teeth to line up.
Old Jan 5, 2013 | 06:15 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by zzjakect
I want to change the distributor in a 1985 Camaro 350 TPI. .
Why? What is wrong with the one you have?
(you can replace the electronics inside it for cheaper than replacing the whole unit )
Old Jan 5, 2013 | 06:19 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
why do you want to change it? Stock stuff is known to be better than aftermarket
Old Jan 5, 2013 | 11:02 PM
zzjakect's Avatar
Car: 1985 Z28
I posted my problem in another post. The engine has no spark.
I changed the following:
Coil
cap
rotor
wires
plugs
throttle contole module
fuel pump
I had the engine control module tested at O'reilly's they said it was good
It was suggested to replace the Pickup coil. I thought if I have to pull the distributor to change the pickup coil I might as well replace the whole thing.
I'm a long way from being a mechanic. But I need to learn this stuff instead of towing it to the shop and having it done for me. It is a hobby car. Any thoughts, tips, ideas are welcome.
Old Jan 5, 2013 | 11:55 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
you can use an ohmmeter to check the pickup coil-a $12 cheapie ohmmeter will be good enough.
Old Jan 6, 2013 | 12:25 AM
tzim350HO's Avatar
Car: 1991 Trans Am GTA
Engine: 350 carbed
Axle/Gears: 7.5 10 bolt 4.10
Make sure you check the distributor is getting power! If it is and you have replaced everything else, it has to be the pick up coil
Old Jan 6, 2013 | 10:51 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
also check the wiring going between the ecm and distributor. i recently had the problem of a wire going bad. caused all sorts of cussing and yelling.
midge54
Jan 29, 2017 07:00 PM
LittleFranks
Sep 17, 2015 12:22 PM
355sbcTPI
Aug 19, 2015 04:38 PM
86IROC112
Aug 17, 2015 07:57 PM
cstrobel65
Aug 15, 2015 10:19 AM
