Favorite cam for Super Rammed 383 ?
Old Jan 18, 2013 | 08:52 PM
Untamed Z's Avatar
10.5 - 1
30 LB.
D Port Heads
58 MM TB
Is it still the road tested Lingenfelter 219 or has something bigger and badder came along? It's in a rag top used for cruising around, just looking for something street/driver friendly that will still be able to get out of it's own way.
Currently has a Crane 2032 that was in it when I bought the car, but for me, it's not enough cam.
Thanks!
Old Jan 18, 2013 | 08:57 PM
Untamed Z's Avatar
Re: Favorite cam for Super Rammed 383 ?
And I'm more interested in seat of my pants torque than hi revving HP.
Old Jan 18, 2013 | 09:44 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
What heads? Does it run ok with that compression and small cam? 219 works well and is pretty mild with a 383. Good torque cam. Abit bigger would be something like the 280xfi but its abit harder to control. Requires good stiff double springs or beehives. Will pull to 5800-6000 if heads are decent and intake is ported a tad. 383 is alot of cubes to feed
Old Jan 18, 2013 | 09:53 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I have a 280xfi in my Super Ram 385 and really like the cam. I agree with Orr, it peaks at 5800(unported SR) on the dyno and I had to use the comp 26918 beehive springs that Comp suggested. 15 years ago I would have went with the Lingenfelter 219 cam but right now the 280xfi seems to be one of the best off the shelf cams for a Super Ram 383.
Old Jan 18, 2013 | 09:54 PM
conlinj's Avatar
Could go with the 268XFi, it dances around the LPE219 cam's specs with the newer lobe profile. Because of those profiles you do need a good set of springs, I chewed a set up with my 280 recently, went with AFR 8019 springs with the new heads to keep everything under control.
-Jim
Old Jan 18, 2013 | 11:20 PM
Untamed Z's Avatar
It has ported corvette d port heads. And to answer your question, its a dog. Obviously can't compare it to my supercharged camaro, but I will say that I'm pretty sure my bone stock 93 Typhoon would run circles around it.
Haven't been to the track or anything with it, but I would be very surprised if it could get into the 13's, and that's with 3.42s. My guess would be around a 14.20 if I had to put money on it.
Old Jan 19, 2013 | 10:17 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah the 2032 cam is a stock replacement type cam and not known for big power but it should still be much quicker than 14's lol. Is the tune good? Those heads like loads of timing. 40 deg cruise and higher, and 36-38 wot.
Bigger cam will help some but depends how ported the vette heads are, if mild work then they probably wont support alot of power
Old Jan 19, 2013 | 07:58 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
That Superram will run great with a wide range of cams.
A friend of mine had the Lingenfelter 383 LT1 in his Impala with the 219/219 cam, 11.0:1 CR. Later he rebuilt it to about 11.5:1 and installed a Comp street series solid roller 242/246 cam and the car was a complete animal at any speed with the 3200 vigilante converter.
Old Jan 20, 2013 | 12:00 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Vette guys like superrams 383-406 with zzx tpis cam and they run pretty hard with good heads
Azrael91966669
25
Jun 20, 2017 04:04 AM
Cameeeero
Sep 18, 2015 04:00 PM
gixxer92
Sep 1, 2015 04:32 PM
LT1Formula
Aug 20, 2015 09:36 PM
