Camshaft Swap
Car: 1992 Camaro RS, 2012 Camaro SS 45th
Engine: L03 305 TBI V8, Blown 6.2L LS3
Transmission: 700R4, TR6060
Axle/Gears: GM 7.6" 10 Bolt 2.73
Camshaft Swap
So I finally found a cam that I would like to put into my LO3 V8 engine. I was wondering if there was anything I need to know before installing one? I do plan on getting new valve springs if I do a swap, and the cam comes with new lifters, is there anything that I need to know before swapping this? Any restrictions? Things is need to do to make it work? Parts I should get to ensure nothing breaks? Thanks for your help.
Heres the Cam:
http://www.jegs.com/i/Comp+Cams/249/CL08-500-8/10002/-1
Heres the Cam:
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Camshaft Swap
Heres the Cam:
Heres the Cam:
http://www.jegs.com/i/Comp+Cams/249/08-500-8/10002/-1
Or if needing new lifters buy the better LS1 lifters for a total cheaper price than the Comp kit
http://www.summitracing.com/parts/NA...9225/?rtype=10
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Camshaft Swap
What else are you going to do to the car? At the very least you will need a full 3" exhaust + headers, new intake, and a tune so it runs good.
Re: Camshaft Swap
Re: Camshaft Swap
You realize you can buy the XR258HR-12 cam by itself for $300 and reinstall your old roller lifters?
Re: Camshaft Swap
This is a good read you should take the time to look at:
http://www.crankshaftcoalition.com/w..._compatibility
Re: Camshaft Swap
That cam will ABOSLUTELY NOT work with stock valve springs. You MUST replace them with decent aftermarket ones.
You don't really need new lifters unless your existing ones are defective in some way.
It's a good choice for an otherwise mostly stock TBI motor though.
Car: 88 Camaro SC
Engine: SFI'd 350
Re: Camshaft Swap
Id probably replace the stock roller lifters if they have a boatload of miles on them. My experience with them is that the rollers start to pit after a while. Get replacements from GM. Some of the aftermarket ones are pure crap.
blackroc68
Sep 1, 2015 08:01 PM
