cam help!
Car: 92 camaro RS
Engine: Moded 350 engine
Transmission: 5 speed
cam help!
i was told that is is an edelbrock, but having trouble identifying it
numbers on it are 0288 D-4 C-4 CWC C-1
numbers on the bottom by the distributor gear are 0414 FB 11 14 88
THANKS!!
THANKS!!
Re: cam help!
CWC is the company that cast the blank.
11 14 '88 looks like a date.
Other than that, not alot of info there.
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
Re: cam help!
Call or email Edelbrock and give them the numbers off the cam. They will be able to ID it by those numbers if indeed it is made by them. I had the same issue with a Comp Cam one email confirmed it.
Re: cam help!
Chances are, that "0414" on the end is probably the cam number. If it is an Edelbrock cam, tell them that number when you get on the phone with them, and they should be able to tell you the specs.
