Last try...
Old Feb 3, 2013 | 07:53 PM
Kennycarlone's Avatar
Car: 91 RS T-Top
Engine: 305 High output TBI
Transmission: automatic 40LB...
Axle/Gears: Ten bolt
Last try...
Well since Ive got my 91 rs 305 TBI I had to replace the cat and flex plate. It ran good for a few hundred miles but then while going down the highway at 65 It started dropping in rpm and acting like it wasnt getting gas so I replaced the fuel pump, fuel filter, air filter, spark plugs and wires. But it continued to do the same thing so I replaced the throttle body possition sensor, throttle body rebuild, fuel injectors, carcoal canister(fuel vapor canister thingy). but the same issues so I replaced the distributor and got a high proformance cap/ rotor, a new icm, new streetfire coil, new plugs.(I have re timed the car back to 0 degrees after anything Ive done, plus I put a new cat back on) but I still get issues, Im not getting a ses light until right before second gear when the car hesitates, when I hit big bumps, or when Im cruising down the highway. does anyone have any ideas of what its doing or how to fix it? The only thing I can think is egr or ecm but the egr seems like it moves fine. so any ideas or questions would be helpful thanks in advance...
Old Feb 3, 2013 | 07:58 PM
Car: 91 RS T-Top
Re: Last try...
Old Feb 4, 2013 | 05:14 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Last try...
have you pulled the codes to see if anything showing?
https://www.thirdgen.org/forums/tech...s-dumbies.html
Old Feb 4, 2013 | 06:27 PM
Car: 91 RS T-Top
Re: Last try...
yes ive ran the codes and it blinks only 12.
Old Feb 4, 2013 | 11:32 PM
Car: 91 RS T-Top
Re: Last try...
could this be a loose ecm power connection, egr, or just a bad ecm? Any suggestions would be greatly appreciated... I love thirdgens but they never seem to work.
Old Feb 5, 2013 | 12:01 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Last try...
I got about 30seconds in an I couldn't handle all of those squeeks and rattles.
Old Feb 5, 2013 | 01:34 PM
Car: 91 RS T-Top
Re: Last try...
haha yeah someone made this hard top into a t top but didnt do a very good job. i have to redo itwhen i can get it working right.
Floridacamaro
May 20, 2015 02:49 PM
Chevy2035
Dec 21, 2014 05:42 PM
88Trans-am
Jul 25, 2014 09:04 AM
Terrence1725
Jan 25, 2014 05:44 PM
