What kind of valve covers are you gusy using on centerbolt heads?
Old Apr 12, 2013 | 05:56 PM
  #51
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: What kind of valve covers are you gusy using on centerbolt heads?
I run Transdapt polished tall valve covers. They're just like the ones pictured by Johnny Blaze but without the ball milling. It was a toss up for me whether to go with any kind of design on the covers. I decided the smooth polished surface works for me. I did have to trim the Crane Gold Race rockers on my intake valves(Twisted Wedge heads) to clear the covers. They work well with my vacuum evacuation suction fittings. No more excessive oil getting picked up.
I was worried about the Transdapt brand. They generally make the cheapest chromed tin junk. However, these covers are pretty nice. I did have to trim a little off of the inside webbing to clear my heads' valve train geometry and I don't use much RTV so I had to use big paper clips to hold the gaskets in place on the covers during install. It worked out great and no leaks. They really seem to compliment the look of my underhood.
Old Apr 12, 2013 | 06:34 PM
  #52
jas2730's Avatar
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
Originally Posted by skinny z
Those look like the Proforms I'm using. Which gaskets are you using and do you have any leaks?
I'm using cork gaskets. Don't know if I have any leaks yet. Tried to fire the car yesterday and the negative battery cable started smoking and the header and brake line started to weld together. Going to redo my ground cables and see what happens.
Old Apr 13, 2013 | 10:07 AM
  #53
skinny z's Avatar
Originally Posted by jas2730
... the negative battery cable started smoking and the header and brake line started to weld together.. .
Yikes! Good look with that. Better check that brake line to see if it's been burnt through.
Old Apr 13, 2013 | 02:41 PM
  #54
Blue1990camaro's Avatar
wow that sounds like a messssss
Old Apr 14, 2013 | 10:13 AM
  #55
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Not finished but here are my valve covers.
I would like to use that style but I haven't seen ones that say "Pontiac"
Old Apr 16, 2013 | 01:31 PM
  #56
you ccan always get them in plain black and make them yourself or have a good painter do it for you, iv seen a 79 TA at a car show with a big block that had the firechicken logo on the valve covers, he had them custom painted with high temp paint and they looked freaking awsome
Old Apr 21, 2013 | 06:50 AM
  #57
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Quick tip for sealing cork valve cover gaskets, use black rtv to stick them to the covers, then apply a very thin coat of grease to the head side. Make sure the rail on the head is clean.Tighten just enough to compress the gasket.You wouldn't think it would work, but I've been doing this for decades without a problem. The grease lets you remove the valve cover and gasket as a unit and you can re-use the gasket several times.
I use the thick steel reinforced cork gaskets instead of the rubber ones to prevent the gaskets from sucking into the valve train under high vacuum situations.
Old Apr 21, 2013 | 09:17 AM
  #58
ghost91's Avatar
Car: 1991 Camaro Z28
I just bought the black proforms like jas2730 has. I'll post pics next week when I get them on. Gotta pick a breather I like and a filler cap.
Old Apr 30, 2013 | 10:27 AM
  #59
ghost91's Avatar
Got mine on this past weekend.
Old May 20, 2013 | 08:48 PM
  #60
Termanalor117's Avatar
Car: 1991 Pontiac Firebird Trans Am
Engine: 1987 Chevy 355 TPI Mild Cam
Transmission: 5-Speed T-5 WC
Where can I get those valve covers?
Old May 20, 2013 | 08:57 PM
  #61
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
http://www.summitracing.com/parts/pr...FSU6Qgod-iUArw
Old May 21, 2013 | 10:35 AM
  #62
ghost91's Avatar
Cheaper on jegs
http://www.jegs.com/webapp/wcs/store...chTerm=141-131
MoJoe
Sep 24, 2015 09:12 PM
gta90
Sep 15, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
mustangman65_79
Aug 8, 2015 01:18 AM
