Does a SBC cam need anything to keep it in place?
Old Feb 15, 2013 | 10:20 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Sorry for the dumb question, I'm pretty sure I know the answer, but this is my first go around with the Chevy V8. Once I have installed the cam, is there anything that goes in between the cam and the cam sprocket? Is there anything to keep it from moving in and out of the block, or does the tension of the timing chain keep it in place? This is a Gen I block, from a 69 Camaro, nothing that i saw came off, so I assume its just the cam and then the sprocket that bolts to it, but I just want to make sure I'm not missing something that keeps the cam from wandering in and out of the block.
Old Feb 15, 2013 | 10:27 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Does a SBC cam need anything to keep it in place?
Flat tappet cams don't , roller cams do
The face of the lobes on a flat tappet cam are at a slight angle so that the lifter pushes the cam to the rear
Roller cams have a flat lobe to suit the roller lifter so they need some means of stopping the cam from walking forward
Factory roller cams use a retainer plate on the cam ; retro fit roller cams require cam button pushing off the waterpump
Old Feb 16, 2013 | 12:18 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
The face of the lobes on a flat tappet cam are at a slight angle so that the lifter pushes the cam to the rear.....What??
Factory roller cams use a retainer plate on the cam ; retro fit roller cams require cam button pushing off the waterpump .....HUH??
Old Feb 16, 2013 | 12:28 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
What??
Flat-tappet camshafts are machined with a slight 0.0025- to 0.005-inch taper on the face of the cam lobe that spins the lifters. This also imparts a
rearward thrust to the cam.
Roller cams don’t have this feature, which is why a thrust bearing or washer is necessary
Old Feb 16, 2013 | 12:32 AM
What kind of engine is that?
Old Feb 16, 2013 | 12:38 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
This retainer plate
fits the recess on the nose of the factory cam (shown below) to hold the cam in. The retainer plate is secured to the two holes tapped into the block
Next QUESTION?
Old Feb 16, 2013 | 12:45 AM
I think you meant timing cover instead of waterpump.
Old Feb 16, 2013 | 01:00 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
On SBC's it is common to put something in the void between the timing cover and the pump back plate so the force is taken by the stronger plate
Some use a threaded arrangement so they can adjust the end play of the cam
"just installing the button is not enough.
Stock small-block Chevy stamped-tin covers are flimsy, and the forward thrust of the cam button can easily deflect these thin covers".
Old Feb 16, 2013 | 01:02 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
SBC flat tappet cam
You may want to enlighten yourself on cams
http://www.chevyhiperformance.com/te...y/viewall.html
2nd paragraph
"Flat-tappet cams for Chevys V-8s incorporate a built-in feature that prevents cam walk, but roller cams do not.
For both the small- and big-block Chevys, cam manufacturers grind a slight taper into each lobe across its face that loads the cam toward the rear of the engine.
GM uses a 0.0025-inch taper while aftermarket cams use as much as 0.005 inch".
Old Feb 16, 2013 | 01:16 AM
That's good to know. Your drawing threw me off since it's a very exaggerated example because .002 isn't even noticeable to the naked eye. I also think it's ground that way more for safety than necessity. Thanks
Old Feb 16, 2013 | 01:24 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
It's ground that way out of the necessity to spin the lifter. The camshaft retention is an added bonus, obviating the need for a retainer plate.
Old Feb 16, 2013 | 01:41 AM
Good point. Like needing an angle on a ujoint.
Old Feb 16, 2013 | 08:25 AM
ex-x-fire's Avatar
Here's a picture of a sbc waterpump w/ a cam bolt, it justs adds alittle pressure to the timing cover when using a cam button.
Attached Thumbnails Does a SBC cam need anything to keep it in place?-5004888232_e185f4de3a_z.jpg
Old Feb 16, 2013 | 09:07 AM
Not only is the cam ground with the rear edge of each lobe taller than the front; but also, "flat" lifters (aka "tappets") aren't "flat". They're actually convex, with a radius of about 6'. Not bubbled-out enough to see with the naked eye, but enough that if you take 2 new ones and put them against each other, you can see daylight around the edges while the centers are touching. In fact that's a quick way to tell if they're too wore out to re-use, at tear-down. (if you're even willing to risk re-using them at all in the first place) This whole system is designed so that ONLY the edge of the lobe touches the lifter face when new, and ONLY out near the edge of the lifter; all of which is designed to make the lifter spin in the bore, thus making the cam/lifter interface a rolling rather than sliding interface. The usual cause of cam wipe-out is failure to spin, but instead the lifter sitting still while the lobe slides across its face. It only takes a few seconds of that at initial startup to permanently ruin a lifter and lobe by digging a bar-shaped rut int he lifter and ruining the "ramp" shape of the lobe, and start it on the fast downhill run to rolling off the lobe.
Edelbrock used to sell a water pump with a bolt setup like ex's pic; might even be what's in the pic; might still sell it for all I know. Unfortunately it was kind of a POS as water pumps go, used some off-the-wall bearing and seal, such that it couldn't be rebuilt, unlike say a Stewart at the time who unfortunately didn't offer one with the cam brace; and used more HP than a Stewart as well. Less efficient as a pump.
The oil pump puts a SIGNIFICANT load on the cam by way of the distributor gear, pulling it into the block as well. Large enough that it's the usual cause of dist gear destruction.
Old Feb 16, 2013 | 10:14 AM
88FormulaF_Bomb's Avatar
Car: 1988 firebird formula 350
Axle/Gears: 2.77
i am a class A troll but i still listen to every word oz says trust him
Posted from Thirdgen.org App for Android
Old Feb 16, 2013 | 12:49 PM
I never use those flimsy sheet metal timing covers. The last one I used was in 2000 and it leaked for absolutely no apparent reason, been using cast aluminum ever since.
Cameeeero
Sep 18, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
NWAsonoma
Aug 18, 2015 05:45 PM
