Smog Pump Mounting Question
Car: 1988 Camaro IROC-Z 350 T-Tops
Hi guys,
I have a question regarding the smog pump mounting. The car I have is an 88 IROC with the 350 engine. The pump was removed when I bought the car, but I am planning on taking the car back to stock due to emissions/ inspection for where I live.
I have the pump and the hoses and all the other components I need except the bolts to hold the pump in place. Does anyone know what size bolt I need to use?
One website said it was a 3/8" bolt with 16 threads per inch, and a length of 3.75" for the bottom bolt. I tried putting one on the bracket and it wouldnt screw into the threads. I didnt want to completely strip the threads in the bracket so I stopped.
Does anyone happen to still have these bolts? Or know the sizes or where I can buy the bolts from?
Any help is very appreciated!
Braden
Braden
Re: Smog Pump Mounting Question
Or better yet, Does anyone still have these two bolts that I could buy from them? I cannot find the size or bolt pattern anywhere....I looked at the alternator and it has Torx bolts, so would the smog pump bolts be torx too?
Engine: 4++,350 & 305 CIs
Yes, they are both torx bolts.. If i remember one is into the block thru the bracket and the other just goes into the bracket.
Thanks for the reply. Do you have any idea where I could find these bolts? Any one on these forums who has taken off the pump and held onto the bolts?
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
just pulled the pump, think I have what u need. I'll measure and send a pic.
long bolt is 6 1/4" and short is 4 1/4 inches. This what you need?
