Would ENGINE be considered a 305 H.O.?
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Alright you guys quick question..I got my 84z28 with a slow LG4 engine in it..and a T5 tranny...FYI Installnig New Ram Clutch and flywheel this upcoming week
Mods to it are.
Hooker 2055 Headers, 3" Straight Pipes, Flowmaster, New distributor, 8.5 MSD Wires, Edelbrock Performer Intake Manifold, Stewart Water Pump, K$N Open Air Element, Rebuilt OEM CC-QUADRAJET, KYB GR-2 All around, Eibach Sportlines All Around, 36mm Sway Bar (front), Wonder Bar, Founders Panhard Rod(Coming in this week)
I know my car has the "peanut" cam...but other than that What do you guys think....305 H.O?????????????
w
Mods to it are.
w On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Would ENGINE be considered a 305 H.O.?
L69s had flat-top pistons for 9.5:1 compression. They also came with more aggressive axle ratios. Mustn't get too serious with the cam while you're at 8.6:1. Nothing more than an XE256.
Car: 1984 Z28
So ur telling that in a staright line a legit H.0 84 z28 stock will beat me?
No it is not.
Yes an actual L69 car, even if bone stock, will drill you so hard you won't know what happened.
Car: 1984 Z28
hmmm....now u got me thinking about that...Now all i need is to find someone with a H.O 305 to really put my cat to the test....I still honestly think he wouldnt win...The advantage I have to is that mines a 5 speed, so...I really am curious...
Well I'll put it this way:
One of my little brothers bought a 84 LG4 car in about 86 or so. It was an auto, but it had 3.23 gears.
My 83 L69 could start out BEHIND his car at a traffic light, and before I was out of 2nd gear, I could pull out and go around him and get in front.
My car had around 60k on it at the time, and his about 35k if memory serves.
That's where you're starting out from.
Car: 1984 Z28
aww man you guys just tore me awpart..=(.....O well....ill just have fun with this engine uintill it "blows" then drop a 350..=)....will installing some 3.42 gears on the rear make a big difference from my stock open differential? kus I really wanna get it done soon but just not sure if itll make a change?
Transmission: 4L80E/4L80E
Car: 01 s10 blazer and 89 bird
Engine: 383 with mystery cam - maybe
Transmission: t56 hopefully
Axle/Gears: 373 geared posi from 2002 z28
But if he were to swaap to a set of 081 heads with 58cc chambers as opposed to 64cc his heads probably have and since they were off swap to a set of shim head gaskets would not that increase his compression ratio may not bring it up to factory h.o. specs but would help and if he swapped to a larger cam he could likely beat a ho 305
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
LG4 and L69 used the exact same heads. Difference in compression is because the LG4 used dished pistons before 1985, where the L69 always used flattops. In 85 the LG4 got the same flattops (and, therefore, the same compression ratio as the L69) but still had the horrible peanut cam.
The exhaust on the LG4 was of the "strangulation" variety, all years (much smaller from the manifolds all the way back to the tailpipes).
JamesC
I'llrocya
Feb 2, 2016 11:43 PM
