Oil Pan for 383
Old Mar 13, 2013 | 01:29 PM
Camaro199677's Avatar
Car: 1985 Camaro Z28
Engine: Work In Progress
Transmission: 700R4/2200 stall/Shift Kit
Axle/Gears: 7.5 Richmond 3.73/Gov Loc Posi
Oil Pan for 383
Does anyone know for a fact on what oil pan can fit really nice with the 3rd gen camaro chassis, longtube headers and cleared for a 383 stroker with 5.7" rods and doesn't cost more than $160? I am thinking of a moroso. I'm just not exactly sure which one to get. It doesn't need to be anything larger than a 6qt pan. Thanks guys
Old Mar 13, 2013 | 08:01 PM
Re: Oil Pan for 383
Your stock 305 one will work fine.
Old Mar 13, 2013 | 09:09 PM
1gary's Avatar
Re: Oil Pan for 383
When you clearance the pan rail,the trick we found is the thickness of a standard paper clip wire is just about right.Don't go nuts there,remember for all the material your remove there is less of a base for the pan gasket to seal.
Old Mar 13, 2013 | 09:30 PM
Re: Oil Pan for 383
Yup...
Although, I find it easier to use something flexible, that can sort of wrap around things; I like to use a wire tie.
Old Mar 14, 2013 | 09:32 AM
UBHSTRY's Avatar
Re: Oil Pan for 383
Stock factory 305 pan on mine....no issues
Old Mar 14, 2013 | 09:44 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Oil Pan for 383
These have some nice options,
http://www.jegs.com/p/JEGS-Performan...26994/10002/-1
Old Mar 14, 2013 | 10:06 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Oil Pan for 383
I have a canton road race pan on mine. Its worth every penny but is way over your limit.
Your stock pan will work fine unless you have a high volume oil pump and plan on high rpm or high G turns/braking.
Old Mar 14, 2013 | 10:48 AM
1gary's Avatar
Re: Oil Pan for 383
Yeah Canton does build good stuff.Agree about high volume pumps too.
The China stuff often doesn't fit well and leaks.Wither it has Summit's name on it or anyone else's.
I suggest to buy a name brand like Hamburger or Canton or use real OEM pans.
Old Mar 14, 2013 | 11:09 AM
Car: 1971 Camaro
Engine: 427
Re: Oil Pan for 383
The Jegs pans I posted are B&B pans. Had one on my big block in the camaro, and got one for the big block in the bel air now. Fits great.
High volume pumps have no business in a V8 chevy anyway.
Canton pans are great too, but over the ops budget as stated above.
Old Mar 20, 2013 | 01:52 PM
Re: Oil Pan for 383
Originally Posted by Johnny Blaze
Hey thanks so much! I have one more question. If I am using main studs instead of bolts should they be compatible for a windage screen if I purchase that jegs street/strip oil pan? It says it comes with one but I just want to double check. I thought the windage screen was connected to the jegs oil pan and doesn't get connected to the main studs.. thanks
Old Mar 20, 2013 | 02:09 PM
Car: 1971 Camaro
Engine: 427
Re: Oil Pan for 383
Windage tray is built in. You will want studs for use without windage tray.
Old Mar 20, 2013 | 10:15 PM
Re: Oil Pan for 383
Thanks so much
Old Mar 21, 2013 | 08:20 AM
TTOP350's Avatar
Re: Oil Pan for 383
You can/should still run a good stud mounted windage tray. The ones built into the pans kinda work but not as well a properly fitted tray thats close to the crank.
I have the on in the pan and a stud mounted one thats a lot closer to the crank/rods.
Old Jul 7, 2013 | 12:58 AM
Re: Oil Pan for 383
Will this work?
http://www.summitracing.com/parts/mo...2/applications
The block is one piece. I just want to find an oil pan that will fit the camaro for a one piece block but I can't find anything except canton and I don't have the money for that. I want to run a high volume
Old Jul 7, 2013 | 04:44 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Oil Pan for 383
Originally Posted by Camaro199677
Will this work?
Go to "Rockauto.com" and search for an oil pan for a 1988 Firebird. They're all one piece or should be and run about $50.00.
Old Mar 12, 2014 | 02:39 AM
Rice01's Avatar
Car: 1988 IROC-Z Camaro
Engine: 383ci SBC
Axle/Gears: 2.77 9 bolt borg warner
Re: Oil Pan for 383
I am in a similar pinch, looking for a one piece seal pan but normal pump. was looking at the CTR-15-010t to put in my 88 iroc-z. on another note will the stock L98 350 pan work with the stroker crank?
Old Mar 12, 2014 | 06:42 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Will this work? http://www.summitracing.com/parts/mo...2/applications The block is one piece. I just want to find an oil pan that will fit the camaro for a one piece block but I can't find anything except canton and I don't have the money for that. I want to run a high volume
I'm not sure myself if there is a difference between one or 2 piece RMS oil pans....if not, I got a pretty cheap stamped steel stroker pan Summit brand that fit fine....just don't try to run Dyno Don headers with it!
Old Mar 12, 2014 | 07:14 AM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Re: Oil Pan for 383
The stock pan will fit.
Old Mar 12, 2014 | 07:31 AM
Confuzed1's Avatar
Car: 83Z28 HO
I tried a reusing the stock pan on my car, and it "fit".....but the rear counterweight on my Scat aftermarket crank was scraping the pan rail in the dipstick area...
Sure you can take a socket and hammer a notch in that area, but you end up slightly distorting the pan rail to do it. Then there's a real good chance
It'll leak in that same spot. There might be other aftermarket cranks that will clear, but my Scat forged didn't.... just a heads-up!
If your using a factory cast crank, then yes- you should be fine with a stock pan.
Old Mar 12, 2014 | 11:11 AM
Rice01's Avatar
Engine: 383ci SBC
Re: Oil Pan for 383
the crank is a cast steel eagle from their street kits.
Old Mar 12, 2014 | 04:39 PM
Confuzed1's Avatar
Car: 83Z28 HO
If you're block wasn't notched in the area of the rear crank throw for it to fit, a stock oil pan should work fine .
Old Mar 13, 2014 | 07:22 AM
bestracing's Avatar
Engine: Broke - 350
Re: Oil Pan for 383
Was your crank forged or internal balanced? We had an aftermarket cast crank in our 388, external balance, and had no problems with using a stock pan.
Old Mar 13, 2014 | 08:53 AM
Confuzed1's Avatar
Car: 83Z28 HO
Re: Oil Pan for 383
It's actually a fairly common issue. I used to think it was odd, or I had some kind of freakish odd-ball crankshaft.
Then I found that nearly every machine shop I dealt with didn't think it was rare at all, and they had clearances numerous blocks for their customers for the same reason. Most of your performance builds are internally balanced. I am actually in the process of upgrading a few things right now on my 400. I can post a crappy pic of where it has to be notched if the OP wants.
But I'm assuming he'd (the OP) would know by now if his block was notched in that area...assuming he has his oil pan off? Either he did it himself, or his machine shop did it...or it didn't need done.
EDIT: And I only brought it up because if you follow the link of the oil pan the OP was considering, (post #14) it was a stroker pan....it's notched out in that area for that reason...a stock pan isn't....
Old Mar 13, 2014 | 09:01 AM
Confuzed1's Avatar
Car: 83Z28 HO
Re: Oil Pan for 383
Oops.....
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
