89 IROCZ Wont Crank
Old Mar 16, 2013 | 10:30 AM
KMdoza7's Avatar
Car: 1989 IROC-Z28 Camaro
Engine: none
Transmission: T-56 W/ Spec 1 Clutch
Axle/Gears: 9 Bolt BW 3.27 Gears
89 IROCZ Wont Crank
I just finished rebuilding my engine on my Iroc, yesterday i dropped it in and hooked everything up,correctly, i think and as i was going to turit on for the first time it wouldnt do ANYTHING. The headlights, taillights and the interior lights do light up though but when you turn the key or put it ACC mode none of my gauges move and the check engine light and the security light do not turn on either. before i did the engine rebuild it would turn on just fine. I just dont know what im doing wrong. ive been searching and searching and nothing helps so i thought i would just start a thread. BTW its my first thread. PLEASE HELP!!
Its an 89 Irocz 350 TPI
Old Mar 16, 2013 | 11:04 AM
KMdoza7's Avatar
Engine: none
Re: 89 IROCZ Wont Crank
ANYONE???????!! PLEASE?????????
Old Mar 16, 2013 | 11:07 AM
90camaro355rs's Avatar
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
I would start at the starter to make sure you have all the wires connected, This is where your power to inside comes from.
Old Mar 16, 2013 | 11:09 AM
KMdoza7's Avatar
Engine: none
Thanks for the reply i really appreciate it. Thats what i have been looking at all this time. I think i have it connected right but im not sure. How many wires should there be on the starter??
Old Mar 16, 2013 | 11:10 AM
if memory serves me correctly there are 3 wires that attach to the ss besides the purple ignition wire, I believe they are a fusable link wire as well, make sure they are good.
Old Mar 16, 2013 | 11:12 AM
KMdoza7's Avatar
Engine: none
So besides the little purple wire, i should have three other wires connected right? two other red wires and my positive battery cable Right?
Old Mar 16, 2013 | 11:14 AM
I think there are 3 fusable link wires, battery and ignition wire, one fusable link wire i think has 2 wires together, look around bell housing make sure one isnt between trans and block.
Old Mar 16, 2013 | 11:23 AM
KMdoza7's Avatar
Engine: none
I checked and everything looked fine, all the wires were connected. I have the purple wire conected to the starter as well as the link with the two wires together, a separate red wire and my battery terminal is also connected. what else can cause this?? im confused
Old Mar 16, 2013 | 11:29 AM
Just a question, is your negative wire conected to the block, is your negative ground strap from block to cowl connected? if all that is good, you have to have a wire missing that powers the ignition switch, Thats all that can be to my knowledge.
Old Mar 16, 2013 | 11:33 AM
KMdoza7's Avatar
Engine: none
Yes my negative terminal is connected to my block, i found a black wire near my fans though. could this be my missing wire?
Old Mar 16, 2013 | 11:34 AM
There are 3 red wires, one goes to ignition switch, one to fan relay, one to the headlight switch. Then purple ignition wire then the battery positive cable, you might trace the red wire from the ignition switch to the starter to make sure it isnt broke somewhere.
Old Mar 16, 2013 | 11:38 AM
Thats prolly the ground for your fans. I would get a test light and check the red wire at the ignition switch there should be an orange wire with power as well when key is turned in acc position, if there is no power there, that is your problem, you will need to find where the break is in the red wire
Old Mar 16, 2013 | 11:48 AM
KMdoza7's Avatar
Engine: none
I found the problem, my wiring harness was loose on the driver side firewall. THANK YOU so much for all your help i greatly appreciate it!
Old Mar 16, 2013 | 11:54 AM
Your welcome. Glad you found it!
Old Mar 16, 2013 | 01:59 PM
KMdoza7's Avatar
Engine: none
Now everything turns on but the check engine light, and the stereo doesnt turn on either. When i try to crank it i hear a click sound coming from the starter. any ideas??
Old Mar 16, 2013 | 02:51 PM
KMdoza7's Avatar
Engine: none
Anyone???
Old Mar 16, 2013 | 03:38 PM
KMdoza7's Avatar
Engine: none
PLEASE can anyone help
Old Mar 16, 2013 | 04:23 PM
UBHSTRY's Avatar
If your getting a click now, try charging the battery
While it is charging, use that time to check your fuses.
I am off to build my AFPR now............
Old Mar 16, 2013 | 04:27 PM
KMdoza7's Avatar
Engine: none
i tried to jump it already and it would do the same thing. the starter just clicks. and the SES light does not come on at all and niether does the stereo.
Old Mar 16, 2013 | 04:29 PM
UBHSTRY's Avatar
Ok....triple check the ground wire, make sure it actually is making good contact to the block. Make sure the starter is not in there crooked, to the point it binds when the gear comes out. Make sure the grounds are connected on the back of the passenger side head.
Old Mar 16, 2013 | 04:31 PM
UBHSTRY's Avatar
Also, just thinking, if you get the soloniod to click, make real sure, even if its the fifth time, that you have the main hot wire to the starter. If its not hooked up or loose, or busted, you will get a click, but no turning over.
Also if that battery is nasty junk, you may not be able to jump it. Got a different battery to try? (sometimes they short out, and use the energy up, instead of using it start the car)
Old Mar 16, 2013 | 04:40 PM
KMdoza7's Avatar
Engine: none
The battery, battery terminals,and starter are all new. I just finished rebuilding my engine. i dropped it in yesterday and i did bolt the ground wires to heads. how many wires should be hooked up to the starter?
Old Mar 16, 2013 | 04:41 PM
UBHSTRY's Avatar
Where are you located?
Old Mar 16, 2013 | 04:42 PM
KMdoza7's Avatar
Engine: none
like where do i live?
Old Mar 16, 2013 | 04:44 PM
UBHSTRY's Avatar
Yes, live. If somewhere your somewhat local, more than willing to help you out. I think your missing a wire, I believe, you should have 3 wires on the main post of the starter. then one little one on the side.
Old Mar 16, 2013 | 04:46 PM
KMdoza7's Avatar
Engine: none
hobbs, new mexico.
I have a little purple wire connected, then i have the positive battery terminal and red wires connected also.
Old Mar 16, 2013 | 04:48 PM
UBHSTRY's Avatar
A little far for me...LOL
Sounds like you have them all connected, id look around down there though to really make sure. I have done it a hundred times leaveing a wire off.
Old Mar 16, 2013 | 04:51 PM
KMdoza7's Avatar
Engine: none
I also checked all my fuses in the fuse box and they were all good. I dont understand why the service engine soon light wont turn on when i turn the key to ACC mode. i tried putting my other ECM from my 88 iroc and it still does the same thing
Old Mar 16, 2013 | 06:46 PM
KMdoza7's Avatar
Engine: none
anyone else??
Old Mar 16, 2013 | 07:21 PM
KMdoza7's Avatar
Engine: none
please somebody?? i cant figure this out still
Old Mar 17, 2013 | 01:19 PM
KMdoza7's Avatar
Engine: none
Can someone please help me here?? im totally lost
Old Mar 17, 2013 | 06:35 PM
KMdoza7's Avatar
Engine: none
please somebody?? im desperate
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
Luigytico09
Oct 1, 2015 08:46 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
