What Flex-Plate?
Old Mar 17, 2013 | 01:23 PM
iroc90dfi's Avatar
Car: 1990 IROC-Z
Engine: 355 TPIS Mini Ram, Vortech R-Trim
Axle/Gears: 3.73 Strange S60
What Flex-Plate?
I have a 1990 IROC 350, pulled the stock motor out and replaced it with a 1992 motor from a truck which was rebuilt. I tried using the Flex-Plate from the 1990 but it will not bolt up due to the bolt holes not matching up. Anyone know what kind of flywheel I need? See pic
Old Mar 17, 2013 | 07:46 PM
Re: What Flywheel?
Keep turning the flex plate (not a flywheel) until the bolt holes line up. Only goes one way.
Old Mar 17, 2013 | 08:22 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: What Flywheel?
You are missing the dowel in the crank flange that makes the plate fit on in the ( only ) correct position
Observe the smaller hole betwen the two bolt holes shown at 2 o'clock in your pic and match that to the same hole in the crank flange where the alignment dowel should be
Old Mar 18, 2013 | 12:27 PM
iroc90dfi's Avatar
Car: 1990 IROC-Z
Re: What Flex-Plate?
Thanks for the feedback, was doing all this in a rush yesterday, but got it figured out.
BadRiggins
Nov 7, 2014 04:55 AM
mds5
Jan 6, 2014 08:16 PM
camaroguy9179
Mid-West Region
Mar 8, 2008 03:58 PM
Mandangelo
Feb 27, 2004 08:29 PM
berlinetta85
Dec 2, 2001 12:38 AM
