Ac removal
Old Mar 21, 2013 | 02:16 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Ac removal
I did a search and couldnt find a thread for just removing the ac. So I want to know what to do I already have the pump off the belt and unbolted just want to know the rest. From other threads people are talking about changing stuff to still have heaters and... I dont care if I have my heater to much but do like being able to have some sort of air movement sometimes.
Old Mar 21, 2013 | 07:12 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Ac removal
Is usual to fit the " a/c delete" box from a car that came without factory air. This allows you to retain a blower motor for air circulation
see
https://www.thirdgen.org/forums/post...61-post15.html
https://www.thirdgen.org/forums/engi...-82-92-ac.html
Other than that you just remove everything that is part of the A/c system
Old Mar 21, 2013 | 10:30 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Ac removal
Don't forget the AC Delete pulley, without it you won't get far as the belt tensioner requires the belt to be routed from that factory position.
If you have an older V-belt car, just take that belt off.
Old Mar 21, 2013 | 04:15 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: Ac removal
OP states
" I already have the pump off the belt "
Old Mar 21, 2013 | 11:29 PM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Re: Ac removal
Ok and if I didnt want to have ny air what would I take off? And where is the ac refridgerant tank? Or is it just in the box? I honestly dont know much about ac stuff
Old Mar 22, 2013 | 01:53 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: Ac removal
Everything from the A/c system.
Follow the lines from the pump to the condenser and the evaporator
There is no tank
The system is full of refrigerant which you are supposed to get removed before opening the lines up
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
