low Oil pressure
Old Mar 21, 2013 | 08:59 PM
67motion's Avatar
low Oil pressure
What will cause the oil pressure to drop to near 0 psi after the engine get up to temp, it is 40psi cold. the engine is a 305 tpi and I do not know how many miles are on the engine. There is no smoke or odd noises and the odometer shows 114,000 miles. engine runs good
Old Mar 21, 2013 | 09:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: low Oil pressure
Try a new sending unit.
Old Mar 21, 2013 | 10:06 PM
Rob's 92 gta's Avatar
Car: 92 firebird gta
Engine: L98 with minor mods.
You can also run a after market gauge from the port of the sending unit just for testing the stock gauge also. The after market gauges are alot more accurate anyway.
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
