should i buy this camaro?
Old Mar 28, 2013 | 05:23 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
how much do you think it would cost to replace the front pump hes talking about is it worth it?
http://atlanta.craigslist.org/atl/cto/3680970951.html
Old Mar 28, 2013 | 05:34 PM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Re: should i buy this camaro?
Yes,yes,yes. Being a southern car, it's possible that it has very little rust. Look the car over real close before you commit to purchase.
Old Mar 28, 2013 | 05:41 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
how much do you think it would set me back to replace the front pump
five7kid's Avatar
Transmission: 4L80E/4L80E
I'd be curious how he knows it's a front pump.
I'd assume a complete transmission overhaul is in order. If you do the remove/install yourself, you're probably looking at $700-$1500 for a rebuild. Add $300-$500 if you have the shop do the remove/install.
Old Mar 28, 2013 | 08:33 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
He said that his mechanic diagnosed it and quoted it at 700 parts and labor
Old Mar 28, 2013 | 08:52 PM
wishoradream's Avatar
Car: 1982 Z28
Engine: 388 SBC
Transmission: TH350 Lockup
I know here in OK, you can get a rebuild with a 1 year guarentee for 900 bucks. So if you're willing to shell out 900-1300 bucks to have the trans rebuilt. The rest of the car looks to be in pretty decent shape, in my opinion. If you want it, and are willing to put the time/work into it. Then anything is worth it right?
Old Mar 29, 2013 | 08:55 AM
splitty's Avatar
Car: 82 Z28
Engine: 370 ci.
Transmission: M 20 4 speed
Axle/Gears: stock open 3.43
I could only view the first pic but it looks like there is some alignment issue between the fender and door.
Old Mar 29, 2013 | 09:47 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Note that a stock '91 RS is going to be either the 5.0l V8 TBI engine, or the 3.1l V6 MPFI engine. Ad doesn't state which...
If the transmission really just needs a pump, they are easy to replace.
RBob.
Old Mar 29, 2013 | 12:03 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Beware of buying any car that "just needs"
...unless you are capable of dragging the dead thing onto your land, and doing the work yourself.
Old Mar 29, 2013 | 10:15 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
If I bought the car, I would just rebuild the trans since your going to have it out anyway. There's a lot of sellers out there that says "just needs" (because there butcher mechanic says so) just to find out that's not the case. You pull the trans, replace the pump, put the trans back in, just to find out that the trans is burned up or the pump wasn't the problem. Then, you get to pull the trans back out so you can rebuild it. That's an awful lot of work when it should of been rebuilt the first time the trans was out.
Wylecoyote08
Nov 6, 2015 03:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Dquickshift
Aug 12, 2015 06:21 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
