I want to put a short ram air intake on my GTA
Old Apr 1, 2013 | 07:45 PM
Johnstonxj's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 3:90
I have a 1988 GTA with a functional ram air hood. I've been looking around at air intakes for it, and really want to put a short ram intake on it like you see in this picture: http://i13.photobucket.com/albums/a2...Picture025.jpg
Is this a good idea, and if I do it, what do I do about the MAF?
Old Apr 1, 2013 | 08:11 PM
rick90gta's Avatar
Car: 1990 GTA
Engine: 5.7L TPI SLP Runners Accel 24lb Inj
Transmission: 700R4 Upgraded Internals, Shift Kit
Axle/Gears: Borg Warner 9 Bolt, 3.27 Ratio
Re: I want to put a short ram air intake on my GTA
if you have a functional ram air hood i assume its the one sold by hawksthirdgenparts.com, which is the only functional thirdgen hood i know of. hawks markets a filter housing kit that matches up to the hood, which incorporates the MAF in the intake tube, all in all a much better setup since the filter isnt sucking air from under the hood. to use a cone filter with MAF you'd have to build some sort of CAI setup and that filter wouldnt work since its oval-shaped to fit the TB on later speed-density cars that dont use a MAF
Old Apr 1, 2013 | 08:13 PM
Johnstonxj's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 3:90
Thats a big help. Thanks a lot.
Old Apr 1, 2013 | 08:18 PM
rick90gta's Avatar
Car: 1990 GTA
no problem just make sure your hood really is the hawks part before dropping the $210 for the ram kit... i've seen non-functional hoods cut out to make them "functional" but the hawks kit wont fit. whether you build a CAI or have the hawks hood and add the ram air kit either is a better option than an open element
Old Apr 1, 2013 | 08:34 PM
Johnstonxj's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 3:90
It is. Turns out I do have the intake box that comes with it. The guy who I bought the car from gave it to me (nice guy). I just need to figure out how to fit it to the intake manifold...
Old Apr 1, 2013 | 08:36 PM
rick90gta's Avatar
Car: 1990 GTA
i've had good luck with hawks customer service you can always ask them for a copy of the instructions, bruce and his team do a great job.
Old Apr 1, 2013 | 08:39 PM
Johnstonxj's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 3:90
Ill probably do that. They could probably steer me in the right direction of tubing for the intake.
Old Apr 1, 2013 | 11:50 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
the intake that i see in that pic is nothing more than an air filter attached to the throttle body- it is kind of the exact opposite of what a "ram air" intake is..
Old Apr 2, 2013 | 01:52 PM
Johnstonxj's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 3:90
Im going to use my k&n airbox instead now
1992 Trans Am
May 10, 2023 07:19 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
