Cam retainer plate bolts don't line up! I have a Vortec block!?
Old Apr 14, 2013 | 12:48 AM
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
My cam retainer bolts won't line up! I took my block to get machined, but the machine shop gave me a different block bc he made a mistake boring it out. He said he could either sleeve it, or give me one of his blocks. So I said ok, gimme one of your blocks. This guy is an engine rebuilder, that's all he does, so I figured he's got tons of sbc blocks laying around. When I saw that the cam plate bolts were not lining up, I got the block number off the rear of the block on top, near where the trans bolts up, So I could look it up online. The number is 10243880. I looked it up online, and everything I've seen has said that it's a 96-00 Vortec block! Is this correct, or am I f'ing something up somewhere? The block I gave him was from an L98 from an 89 Trans Am. I was gonna use the heads that came on the motor, cuz the guy i bought the motor from had them ported and polished and cut for bigger valves and springs. If it's a Vortec, I'm gonna have to buy a new set of heads!
Old Apr 14, 2013 | 12:52 AM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
Re: Cam retainer plate bolts don't line up! I have a Vortec block!?
I've used vortec heads on a regular block, so I don't see why your regular heads won't bolt on a vortec block.... maybe you need the cam retainer plate for the vortec, and you'll be fine.....
but then again, might have to do some research...
Old Apr 14, 2013 | 12:55 AM
Engine: SBC 350
I thought Vortec heads have a different head bolt pattern?
Old Apr 14, 2013 | 12:58 AM
Engine: SBC 350
Or is the intake bolt pattern just different?
Old Apr 14, 2013 | 01:04 AM
greggbruce's Avatar
yep, different intake
Old Apr 14, 2013 | 01:12 AM
Engine: SBC 350
Is there anywhere I can get a cam plate for this block? The bolt holes on my cam plate are too far apart to fit the holes in the block. I could probably ask the guy at the machine shop. He probably has one laying around.
Old Apr 14, 2013 | 01:16 AM
greggbruce's Avatar
that's where I'd start, since he gave you the block....
but the dealer should be able to get one as well...
Old Apr 14, 2013 | 01:24 AM
Engine: SBC 350
Jeg's actually sells one for $13.99. It's hard for me to get to this guy's place because he's only open till 5:00 P.M. and I have work. I might just buy it. Idk. Thanks for all the help!
Old Apr 14, 2013 | 01:26 AM
greggbruce's Avatar
I would at least call the machinist first, maybe he'd mail you one for free....
Old Apr 14, 2013 | 04:54 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The bolt holes on my cam plate are too far apart to fit the holes in the block. .
Because there are two different versions of the retainer plate; early and late
3.62" Bolt Center, and 3.294" Bolt Center
http://www.summitracing.com/search/b...s?autoview=SKU
Old Jul 25, 2020 | 10:36 AM
Travis137t's Avatar
help i need to know where to get the smaller retainer plate
Old Jul 25, 2020 | 06:25 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
GMs ZZ4 timing set comes with both plates, hardware and a single roller chain.
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
mhatfield 14
Oct 24, 2015 07:48 AM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
