Grinding/rattling from engine at idle??!
Old Apr 28, 2013 | 10:32 PM
servo2055chevy's Avatar
Car: 1988 Camaro Base model
Engine: 305 LO3 5.0L V8 TBI
Axle/Gears: 10Bolt Rear, Not sure the gearing
I got a noise at idle. It's like a weird rattle. It sounds like its a pully. Like a bearing or something. Could it be the tensioner?? All of my pulleys are tight. Alternator is good, a/c compressor good. It doesn't do it all the time though?
Old Apr 28, 2013 | 10:44 PM
Joe Tag's Avatar
Re: Grinding/rattling from engine at idle??!
Given the limited information you have here, I'd check the tensioner pulley bearing or the water pump. Possibly the clutch for the A/C compressor.
Old Apr 28, 2013 | 10:45 PM
It's not coming from a/c. It sounds the same even when it's not engaged and the water pump is new
Old Apr 28, 2013 | 10:46 PM
It sucks because its intermittent
Old Apr 28, 2013 | 11:10 PM
Joe Tag's Avatar
Best I can say is get out and hunt it down when its happening. The tensioner pulley is only like 12 bux and takes maybe 15 minutes to change if you want to just take a shot at it.
Old Apr 28, 2013 | 11:11 PM
Yea I'll probably do that. I need a belt too
Old Apr 30, 2013 | 07:44 AM
Well I installed new belt and tensioner. Still a rattle. It sounds like a grinding rattle?? I don't understand it
Old Apr 30, 2013 | 07:45 AM
It's like a chatter
Old Apr 30, 2013 | 07:04 PM
JesseShredd's Avatar
Car: 1992 Camaro RS
Engine: 1978 L82 355
Ps pump or water pump.
Old May 1, 2013 | 09:46 AM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Smog Pump.
Old May 1, 2013 | 09:51 AM
How hard to change smog pump?? I do hear it louder underneath the car
Old May 1, 2013 | 06:12 PM
RyanJB's Avatar
It's not terrible. I just did the delete on mine. I had a very similar sound but mine was intermittent. Especially when hot
Old May 1, 2013 | 06:32 PM
What are the steps taken to install delete pulley???
Old May 1, 2013 | 06:38 PM
KMdoza7's Avatar
Car: 1989 IROC-Z28 Camaro
Engine: none
Transmission: T-56 W/ Spec 1 Clutch
Axle/Gears: 9 Bolt BW 3.27 Gears
Well there isnt much info that your giving out but i had the same problem with my camaro. go under the car and check your torque converter to flexplate bolts, see if they are loose or if you are missing some bolts.
Last edited by KMdoza7; May 1, 2013 at 06:40 PM. Reason: you said its louder underneath the car....im 95& sure its the torque convertor to flexplate bolts
Old May 1, 2013 | 08:34 PM
Ok I'll try that
Old Jul 1, 2013 | 02:34 PM
ApolloX64's Avatar
Car: 1992 Pontiac Firebird Formula WS6
Axle/Gears: 3.23 L-Slip w/ discs
Did tightening the flexplate bolts fix it?
Interested in knowing what you did if you solved it since I have the same situation.
Old Jul 2, 2013 | 01:17 AM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
btw if u delete the smog pump don't buy a new pulley change the routing, heres the link. https://www.thirdgen.org/serpentine
Old Jul 4, 2013 | 04:45 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
I'm interested in what this might be as I have the same thing very occasionally. I replaced my tensioner, removed my ac, smog, new water pump- only the alternator remains- could it be that?
Old Jul 5, 2013 | 02:28 AM
Dr_Zed28's Avatar
Car: 1986 Camaro Z-28
Engine: 305 V8 4bbl.
Is the noise happening at specific RPMs? Does your car idle at 500 and occasionally jump 600-700 (makes grinding), returning to idle around 500 (no noise)?
Old Jul 5, 2013 | 08:35 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Usually when you're moving and put the clutch in to coast and then at idle at tickover rpm.
Old Jul 10, 2013 | 05:55 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Just a note on the A/C pulley. The A/C pulley is supported by a bearing and whether the clutch is engaged or not, that bearing carries the full load of the pulley. The bearing will be noisy whether or not the compressor is engaged.
TC bolts are a definite possibility. Also, I see alot of issues with serpentine systems producing belt noise that can sound alot like bearing noise. It is most often caused by a slight misalignment of the pulleys that forces the back of the belt to drag at an angle across the water pump pulley. Look for a variation in the pulleys and for the belt to enter and exit the water pump pulley at slightly different points front to rear. It doesn't take much of a difference to make alot of noise. Try a little WD-40 on the back of the belt and see if it goes quiet for a short time. If so, then you need to realign the pulleys. On GM products, adjusting the P/S pulley 1/16 to 1/8 inch forward usually does the trick.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
