Random Starter/Ignition problem
Old May 1, 2013 | 05:14 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
It seems as if my car will not turn over, at random....
1989 Firebird Formula, TPI
It has happened when the car is cold, warm, sitting for a long time or just recently driven.
I hear a *click* (as usual) when i put the key in the ON position, then when i turn to crank, nothing happens.
I try again a half hour later, and it works just fine.
Note: This problem has been happening for YEARS, and yes, i have tried replacing the starter
Old May 19, 2013 | 02:22 PM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
Re: Random Starter/Ignition problem
Mine just started doing this. Changed the starter no difference.
I hear the click every time. Sometimes it starts first time, some second time, sometimes after 5 clicks.
Old May 19, 2013 | 02:25 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Tried changing ignition switch?
Old May 19, 2013 | 06:41 PM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
After reading what others were saying I took the cables off again (had already done this). No rust, no corrosion, everything tight.
Sand papered the ends and the battery terminals (side posts). No problem now. Go figure.
Old May 20, 2013 | 05:25 PM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
That gremlin is back today. Ig switch is a good idea. Rarely change those so it didn't come to mind.
Old May 20, 2013 | 08:48 PM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
changed ignition starter switch and found that the key switch doesn't seem to move the rod to the switch as it should.
Have any of you seen this to wear out?
http://www.oreillyauto.com/site/c/de...gnition+switch
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
