Moroso Engine Mounts
Old May 1, 2013 | 08:38 PM
wishoradream's Avatar
Car: 1982 Z28
Engine: 388 SBC
Transmission: TH350 Lockup
Anyone using these? How do you like them?
Old May 1, 2013 | 08:53 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Moroso Engine Mounts
part numbers?
Old May 1, 2013 | 08:55 PM
Car: 1982 Z28
Engine: 388 SBC
62500 on jegs
Old May 1, 2013 | 08:57 PM
Car: 1982 Z28
Engine: 388 SBC
Someone gave me a set of those, just trying to figure out if it's worth it to buy the frame mounts and use them
Old May 1, 2013 | 11:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Ah, the solid motor mounts. I used them years ago on my race car. They eliminate flex and twist compared to normal mounts and you don't need to chain the left front of the engine down.
Good for a race car but for a street car, you would be better off with a set of poly mounts which are much better than the factory rubber.
I use front and rear motor plates now. No mounts on the sides of the engine which can cause cylinder wall distortion.
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
