alternator problem after manifold install
Old May 16, 2013 | 07:30 PM
FosterK's Avatar
Hey everyone, i recently put a new carb and intake manifold in my car. I had to remove the alternator and bracket to do so, after the install i put the alternator back on and it is no longer.giving a charge. Battery is at 12.3V at 3000rpm. The only thing i could think of was one of the wires isnt getting a good enough connection so i checked them, wirebrushed one, and still no charge, why would it stop working after being taken off and put back on?
Old May 16, 2013 | 08:51 PM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
Re: alternator problem after manifold install
That's odd...unless something was damaged during the install. Take it to autozone and have those guys check the system. Or, get a new alternator, install it and see if that fixes the problem. If it doesn't, just return it, and attempt to isolate it to the wires or something. I assume the connection to the alternator is in good shape? Also, why is 12.3V at 3000rpm a bad thing? And how old is your battery?
RazorN8
Jan 7, 2022 11:44 AM
rocn7roc
Sep 21, 2021 02:16 PM
dutch930
Sep 11, 2015 06:58 AM
Fronzizzle
Aug 17, 2015 02:52 PM
