cam question
Old May 19, 2013 | 08:26 PM
backoffjack's Avatar
Car: 89 Camaro RS
Engine: 350 40 0ver
cam question
recently bought a 350 which is not currently a roller but can and will be. I was told that I could use the came out of my 305 however I don't know if I want to and thought I would come ask someone with experience for suggestions
Old May 19, 2013 | 08:48 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: cam question
The cam in your 305? I definatley would not use the cam out of a 305 TBI. That is the smallest cam ever put in a v8 F-body. You can find a used Lt1 cam pretty cheap which is a little better than a stock 350 TPI cam.
Old May 19, 2013 | 08:55 PM
Car: 89 Camaro RS
Engine: 350 40 0ver
Re: cam question
right on, I will look on ebay and see whats out there
Old May 19, 2013 | 08:59 PM
Car: 89 Camaro RS
Engine: 350 40 0ver
Re: cam question
http://www.ebay.com/itm/Small-Block-CHEVY-HYD-ROLLER-LT1-LT4-PERF-510-20-CAM-/171040588506?pt=Motors_Car_Truck_Parts_Accessories&hash=item27d2d042da&vxp=mtr
would you be willing to take the time and tell me if this is worth while
Old May 19, 2013 | 09:15 PM
jas2730's Avatar
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
Re: cam question
Small Block Chevy Hyd Roller LT1 LT4 Perf 510 20 Cam | eBay
Depending on what heads your planning to use it could be worthwhile. Stock heads won't handle that much lift.
Old May 19, 2013 | 09:18 PM
Car: 89 Camaro RS
Engine: 350 40 0ver
Re: cam question
I sure they are stock heads but the motor was rebuilt and bored 40 over before, guess I will have to look into that
Old May 19, 2013 | 09:37 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: cam question
A quick rundown on cams for stock thirdgen's. Keep the duration below 220/220 and the lift under about .470/.470. Anything bigger and the stock ECM will require reprogramming and any lift bigger than .470 will require different springs.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
