battery disconnect switch
Old May 21, 2013 | 07:49 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
how do i hookup the alternator part to a two post kill switch (battery shutoff switch)? my switch shuts off but car still runs. do i run a wire from the battery swtich "off" to the red wire on the alt or the connector part on top of the alternator? alt i have http://www.summitracing.com/parts/sum-811001
Old May 22, 2013 | 11:26 AM
1killerolds's Avatar
Re: battery disconnect switch
run a min 10ga wire from alternator battery terminal to the off side of the switch. or you can use a high current relay or a battery isolator solenoid under the hood to open the charge wire.
Old May 25, 2013 | 03:34 PM
Engine: 355
i hooked the wire up to the terminal on the alt and it keeps running. is it the wrong connection? the bolt on alt is where i hooked it to. or do i have to hook it to one of the wires to the white or red wire on alt?
Old May 29, 2013 | 11:43 AM
did you remove the original charge wire on the alternator post?
Old May 29, 2013 | 07:06 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
http://forums.corral.net/forums/drag...-once-all.html
https://www.thirdgen.org/forums/orga...ttery-cut.html
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
luvofjah
Sep 3, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
andy74
Sep 3, 2015 08:41 AM
