Steering column swap
Car: 91 Chevy Camaro RS
Engine: 305 TBI
I was wondering if any one knows what vehicles steering wheel columns can be used in a 91 camaro. I want to go to a junk yard and pull one but not sure which ones will fit. Any help would be great.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Steering column swap
You will be better off repairing your column, the columns are specific for the thirdgens and some 88 and 89-92 use vats witch you will need to swap over your lock cylinder or bypass the vats.
Engine: 305 TBI
I do have a new lock cylinder and my problem is the bearings on the upper part of the shaft in front of the pivot. I can not find these bearings any where they completely fell apart.
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Also, they come right apart. Just put the ***** back into the plastic retainer, coat it with grease to hold the ***** in place and just put it back together.
evilstuie
Feb 28, 2016 03:33 PM
