Oil On My Rear Bumper??
Car: '82 Z28
Transmission: TH-350
Axle/Gears: Posi
A while ago I realized my car is basically drinking oil. A lot. A couple weeks after my oil change I was low. Then I looked at my rear bumper and saw everything coated in a noticeable layer of oil. I do mean everything- Bumper, licence plate, tail lights... I don't know what it could be other than a blown rear main. Anyone have any insight?
Car: '82 Z28
Axle/Gears: Posi
Re: Oil On My Rear Bumper??
That's what I would think if it didnt come back when I wiped it off... And I really can't sell or trade it with that large of a leak.
Yup, pretty typical. (although actually, if you took the bumper off, you'd probably find it on the inside as well; since everything that is in the air up under the car, including leaked oil, passes that way as the car goes by)
Most likely not the rear seal.
A better idea, before just jumping to the most expensive and painful conclusion possible, is to LOOK AT IT and see where it's coming from.
Not a lot of rocket science, really.
If it's REALLY all caked up with the funk up under there, take it to the quarter car wash first, and STERILIZE it; then it'll be a piece o cake to see where new oil is.
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
I had the same problem and it ended up being my valve seals. Mine wasn't going through it as fast as you but I had to add oil every once in a while.
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
could be as simple as a valve cover gasket that is bad. Clean the engine.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
Navy8125
Aug 21, 2015 09:32 AM
