what would be the reaction if i put 3:73 gears on my 91 z28 camaro 5sp manual
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: what would be the reaction if i put 3:73 gears on my 91 z28 camaro 5sp manual
What gear is in there now? If you have 3.42s in there don't bother with 3.73s.... if you have 2.76-3.23 then definitely get 3.73s
Car: 91 z28
Transmission: 5 speed
I dnt know, i saw on this website that they came out with 3:42s, and that make me think just to leaved with those gears.. But i dont know, do you know a way i could find out which ones i have?
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Check the RPO codes but the only way to be 100% sure is to pull the cover and count teeth.
Do you have the 205hp or 230hp engine?
Car: 91 z28
well i dont know which one i have, if the 205hp or 230hp...
im new into this, and my friend told me change the gears to 3:73, and my cousin told me the same thing because he put 3:73 to his mustang and he said he really like it, and i started liking the idea of putting the 3:73 gears to my camaro...
but now i got another problem my camaro shut down yesterday while driving at 20mph and it didnt started :/... the rpms went to 0 and the car die -_-... you got any idea of what could of be?
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
Car: 91 z28
Is not out of gas. And yes it does crank.... Hopefully is nothing bad...
Car: '88 Trans Am
Engine: 5.7L TPI
As far as the correct gear ratio goes you CANNOT trust the RPO codes on 30 year old cars we tend to change gear ratios drivetrains etc..... The only way to know exactly what you are dealing with is to do a rear end service take the differential cover off and look at the ring gear that will say something like 41-10 etc. The divide the numbers 10÷41=4.10 your rear end could probably need servicing anyway
On to your new issue either your ICM (ignition Controll module) has gone bad or possibly your fuel pump went south.
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
1992 Trans Am
May 10, 2023 07:19 PM
dhonda200
Aug 11, 2015 11:50 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
