vortec 350 flutter in 2nd gear
Old Jun 12, 2013 | 11:41 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
I'm having an issue with my newly rebuilt motor. The issue Im having is that if I get into the gas or go WOT it runs fine through 1st, but at the end of 2nd the motor starts to flutter in and out like its not getting enough gas to accelerate more. Iv put in a new distributer, rebuilt my carb, installed a new carb fuel pump and ask still getting the same issue. Any advice or know where I can look?
Old Jun 14, 2013 | 12:50 AM
Engine: L31 350
Re: vortec 350 flutter in 2nd gear
Bumb
Old Jun 14, 2013 | 03:58 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Originally Posted by evilemokid94
Bumb
So what happens if you do a run through 2nd gear only? Ie a 15 mph roll or something? Same thing?
Old Jun 14, 2013 | 08:40 PM
Engine: L31 350
Same thing
Old Jun 14, 2013 | 10:18 PM
1gary's Avatar
Where are in the timing??. Locked dizzy??.36 degrees total??. All in by 2500??.
You said you put on a new pump,but didn't say what kind or brand or what the fuel pressure is while it is acting up.
MustangBeater20
Oct 29, 2022 09:20 PM
Derick15
Sep 17, 2016 05:28 PM
db057
Aug 22, 2015 08:17 PM
Jlanz55
Aug 17, 2015 07:15 AM
dhonda200
Aug 11, 2015 11:50 PM
