Oil Pan "Spreader bars"
Old Jun 13, 2013 | 07:32 PM
RWO3's Avatar
Car: '84 Camaro Sport Coupe
Engine: 355
Axle/Gears: 3.08
I was looking at a few other small block chevys in the shop and I noticed that they all had these plates that go under the oil pan bolts, apparently to distribute the bolt torque.
I bought a new summit oil pan and it didn't come with any. Is it common to use these? Do you guys use them? Are they good to have?
Thanks.
Old Jun 13, 2013 | 07:41 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Oil Pan "Spreader bars"
Its a good idea to use them if you can, felpro s one piece pan gasket has metal inserts to help prevent over tightening.
Old Jun 13, 2013 | 07:47 PM
RWO3's Avatar
Engine: 355
Axle/Gears: 3.08
Do you know who makes them? I've only found these; http://www.summitracing.com/parts/ham-1178/overview/ but they say they are only for Hamburger pans.
Old Jun 13, 2013 | 10:17 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It was a good idea when oil pan gaskets were cork and could easily be crushed from over tightening. Torquing pan bolts or anything that used a cork gasket was critical and a bit of thread sealer on the bolts prevented them from loosening off.
The more modern rubber, neoprene or metal insert gaskets as mentioned above can be tightened up more without crushing the gasket.
I use a one piece Felpro gasket on my engine. Providing it doesn't get damaged, I keep reusing it every time I pull my pan and I still torque my pan bolts.
Old Jun 13, 2013 | 10:51 PM
1gary's Avatar
The more recent oil pans it not a back idea to use them because of imported junk pans sold today.They just don't fit well.Many leak even with the current gaskets out there.
BDR
Nov 7, 2015 03:05 PM
project89
Sep 22, 2015 09:35 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
